Dragon Box Chinese Phone Tool |
12-21-2012, 19:05 | #1 (permalink) | |||||
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | SAMSUNG R5830 6803H Read, Write, Format @ Error CODE;00--> CMD_EERPR--> TIMEOUT DONE, Error CODE;00--> CMD_EERPR--> TIMEOUT Problem , i am trying to changed the imei of handset but get this Problem so now what i do ? Simple Method to solved this problem using dragon box , Quote:
Step 3 Formatting Quote:
Problem , i am trying to changed the imei of handset but get this Problem so now what i do ? Quote:
The Following 4 Users Say Thank You to JONONItelecom™ For This Useful Post: |
12-22-2012, 06:36 | #3 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | You mean sometimes USB Power not enough for Dragon Box. Yes, if you are not using good power supply to the Computer. This may happen. Thank you for your suggestion to other dragon users. BR Dipendra Pathak |
08-01-2013, 10:28 | #4 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Wazirabad Delhi
Member: 1660122 Status: Offline Thanks Meter: 95 | Plz Flash file of Chaines Nokia 308 SPd..6530A Chaines Nokia N308 SPD...6530A.......hanging problem. Format By Gpg Dragon.......handset dead when i trying to write of backup flash file........its showing following error >>> Getting Mobile Connection Info... VCC Pin:10, GND Pin:1, 4, Signal Pin:2, 3, 5, 6, 7, 8, 9, 11, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:9 D-:8 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM10 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 CPU Name:6530 Flash ID:0xC860170000000000 Flash Name:SF_GD25LQ64 Flash Size:0x00800000 -> 8M Baud Rate is Switched To:921600 >>> Writing Flash File... Full Flashing .. Error CODE:FF--> CMD_EERPR --> UNKNOWN but still read ok........ >>> Getting Mobile Connection Info... VCC Pin:10, GND Pin:1, 4, Signal Pin:2, 3, 5, 6, 7, 8, 9, 11, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:9 D-:8 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM10 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 CPU Name:6530 Flash ID:0xC860170000000000 Flash Name:SF_GD25LQ64 Flash Size:0x00800000 -> 8M All Done... |
08-06-2013, 04:54 | #6 (permalink) |
Junior Member Join Date: Jul 2005 Age: 42
Member: 165269 Status: Offline Thanks Meter: 2 | >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM14 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version: >>> Downloading First Boot... Error CODE:00--> CMD_EERPR --> TIMEOUT Always get this, plz help me! |
