AVATOR BOX (China Phones Service Tool) |
07-03-2011, 09:43 | #1 (permalink) |
Insane Poster Join Date: May 2008
Member: 775682 Status: Offline Thanks Meter: 14 | avator box format error??? (Solved) Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:xxxx, HardwareVer:xxxx, SoftwareVer:xxxx Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: JXZ56_09B_V1.00 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done ========================================== 2nd case when I try to format the same problem for E72 clone (chinnesse Phone) Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:xxxx, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Failed to send Boot (bar indicator only reach 67%) Anyone or AvatorBox Team can give me solution???? Thanks Abu |
07-03-2011, 10:15 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Hi good to know that your 1st case has been successfully solved now moving on your 2nd case.. you did not post about your phone problem. secondly about it stops .. try to press power on till whole format process done and post results. BR AvatorBox Team Quote:
07-03-2011, 10:27 | #3 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
then format. problem will be slve. | |
07-03-2011, 10:38 | #4 (permalink) |
Member: 782530 Status: Offline Thanks Meter: 8,136 | & here is your flash file. http://forum.gsmhosting.com/vbb/6987764-post89.html http://forum.gsmhosting.com/vbb/6724110-post1.html |
07-04-2011, 06:48 | #5 (permalink) |
Member: 775682 Status: Offline Thanks Meter: 14 | thank you GSM univeral I did press power button but not solved, I try to read info / read flash but same problem occur, the problem is : - hang (some times become white screen) - vibrate after power on - can't off when I push off button. - phone off itself after a few second. Now E72 clone my customer phone become DEAD. Please give me further solution for this problem. Multi Elle, I will try your suggestion after all s/w trick I got. Oh yeah, for Nokia Z2000 the problem solved already by formatting, so I didn't make further move (flash, etc) Anyway thanks for the file. abu Last edited by abu nawaz; 07-04-2011 at 06:54. |
The Following User Says Thank You to abu nawaz For This Useful Post: |
07-04-2011, 11:03 | #6 (permalink) | |
1st read buckup flash file. then test with this file. i hope your problem slve. Download E72_china.zip for free on Filesonic.com | |
07-05-2011, 03:51 | #7 (permalink) |
Member: 775682 Status: Offline Thanks Meter: 14 | Log Read Info when I try to using "Internal Boot" Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:xxxx, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Log "Formating" when I try using with "Internal Boot" Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:xxxx, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Unlocking all blocks before program/erase... Unlock Done. Formatting... Error: Erase Flash Log when I write flash using "Internal Boot" Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:xxxx, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Analysis the file, Some file may need a long time... The file has not been encrypted. Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable Error: Failed to read AC Avator Team! Please kindly advise or others members please kindly me solution for this kind of problem. thanks Abu |
07-05-2011, 04:23 | #8 (permalink) |
Member: 782530 Status: Offline Thanks Meter: 8,136 | Try 6600L-COM and 468000 can working or no same then need to rehot the flash chip and try again |
The Following User Says Thank You to FullFlashPak For This Useful Post: |
07-05-2011, 06:43 | #9 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: AvatorBox MCU
Member: 1427447 Status: Offline Sonork: 100.1596998 Thanks Meter: 4,218 | Hi . Still i dont understand . why you edited your logs With XXXX How to help you. if you not Extract logs Regards Avatorbox Quote:
07-05-2011, 07:58 | #10 (permalink) |
Member: 775682 Status: Offline Thanks Meter: 14 | oke avator team, pls kindy check it out, this log before I choose "Internal Boot" in boots column Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Failed to send Boot Below log after I choose "Internal Boot" Read Info Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Formatting Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Unlocking all blocks before program/erase... Unlock Done. Formatting... Error: Erase Flash write flash (internal boot) Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00570002xDGB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Analysis the file, Some file may need a long time... The file has not been encrypted. Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable Error: Failed to read ACK. Waiting your advise. txs |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
