AVATOR BOX (China Phones Service Tool) |
07-27-2018, 10:14 | #16 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Operation : Write Flash Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek USB Port_V1632 (COM54) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6755 [MT6755], SW: 0001, HW: CB00 BL Ver: FE; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Any errors manually select "ConnectMothods" and try again Connection type:brom Configuring DRAM... Waiting for DRAM detection...OK Sending 2nd DA ... SYNC... OK 2nd DA...OK Retrieving RAM Configuration ... SRAM Size: 0x40000 DRAM Size: 0x80000000 Retrieving Memory Configuration ... EMMC CID : 150100524836344D4202A432909714BB EMMC Vendor: Samsung_RH64MB EMMC Size : 64GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 58.24 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Getting USB SPEED: full-speed Auto usb high speed ...ok Checking scatter file ... > Scatter File Ok Checking config > Config.. ok Checking Firmware with Current SoC ... > firmware... ok. Firmware Type : Verified Writing recovery > ok Writing md1img > ok Writing md1dsp > ok Writing md1arm7 > ok Writing lk > ok Writing lk2 > ok Writing boot > ok Writing logo > ok Writing tee1 > ok Writing tee2 > ok Writing secro > ok Writing system > ok Writing cache > ok Writing userdata > ok All done. Operation Done: 00:09:23 Avator Pro SW 2.1 |
08-02-2018, 10:29 | #17 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | mmx a107 successfully flashed from dead Operation : Write Flash Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek PreLoader USB VCOM_V1632 (Android) (COM32) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6582[MT6582], SW: 0001, HW: CB00 BL Ver: 01; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100513758534142 EMMC CID : 150100513758534142 EMMC Vendor: Samsung_Q7XSAB EMMC Size : 8GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 512 KiB User Area : 7.28 GiB Boot Completed. Checking userdata encryption... Userdata State : Encrypted Checking scatter file ... > Scatter File Ok Checking config > Config.. ok Checking Firmware with Current SoC ... > firmware... ok. Firmware Type : Generic Writing mbr > ok Writing ebr1 > ok Writing uboot > ok Writing bootimg > ok Writing recovery > ok Writing sec_ro > ok Writing logo > ok Writing android > ok Writing cache > ok Writing usrdata > ok ReChecking info......ok All done. Operation Done: 00:06:18 Avator Pro SW 2.1 |
08-02-2018, 10:44 | #18 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | karbonn a6 privecy lock done peration : Remove Privacy Lock Codes Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek PreLoader USB VCOM_V1632 (Android) (COM32) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6572[MT6572], SW: 0000, HW: CA01 BL Ver: 01; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 700100454534454134 EMMC CID : 700100454534454134 EMMC Vendor: Kingston_EE4EA4 EMMC Size : 4GiB BOOT1 Size : 2 MiB BOOT2 Size : 2 MiB RPMB Size : 512 KiB User Area : 3.53 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Removing privacy lock ... All done. Operation Done: 00:00:06 Avator Pro SW 2.1 |
08-02-2018, 11:46 | #19 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | k50a40 frp done Operation : Reset FRP Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek PreLoader USB VCOM_V1632 (Android) (COM32) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6752[MT6752], SW: 0001, HW: CA01 BL Ver: 01; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100523832314D42 EMMC CID : 150100523832314D42 EMMC Vendor: Samsung_R821MB EMMC Size : 16GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 14.56 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Resetting DATA... FRP DATA Found, Reset ok. Failed to format Flash... |
08-06-2018, 10:26 | #20 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | MICROMAX Q461 IN LOGO DONE Operation : Write Flash Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek PreLoader USB VCOM_V1632 (Android) (COM39) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6735 [MT6735M_S01], SW: 0000, HW: CA00 BL Ver: 01; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100514E31334D42 EMMC CID : 150100514E31334D42 EMMC Vendor: Samsung_QN13MB EMMC Size : 8GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 512 KiB User Area : 7.28 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Checking scatter file ... > Scatter File Ok Checking config > Config.. ok Checking Firmware with Current SoC ... > firmware... ok. Firmware Type : Generic Writing lk > ok Writing boot > ok Writing recovery > ok Writing logo > ok Writing secro > ok Writing tee1 > ok Writing tee2 > ok Writing system > ok Writing cache > ok Writing userdata > ok ReChecking info......ok All done. Operation Done: 00:05:20 Avator Pro SW 2.1 |
