Need explenation. (Answered) Today I want to read info from china blackberry b9630. This set totally dead,and I found log: ]Initializing... DA_LIB_VER_3.3.4.5 It is sensing the pinout fast,please hold on the phone Power key RXD=13 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 I think that it was hardware problem, cpu or flash ic. But I need explenation about that logs. |
Hi Check Your Cable Or Jack If They Are Perfect Than It Is Bad Flash Ic. Check Here : http://forum.gsmhosting.com/vbb/7221705-post16.html BR AvatorBox Team |
Hi What Version you Are using ? As per your logs . you are using old Version. Always Use Latest Version Regards Avatorbox Quote:
i use ver5.400. cable was ok (JIG: P-12C), last week i've already fix the same type of phone. but the owner said that the set was repair by other technisian before. and after disassembly, i found much flux in it, so maybe they overheat ic, and make it damage. i will try using ver5.510 and post result. thnx for atention.! btw i have 3 china boxes, avator is new one for me, but after test, avator detected tx/rx very fast than the other. good tools.! |
try version 5.510 and using every boots version but still same. I’m think that’s h/w problem, but need to know for sure, which part was damage, cpu or flash. Tick on “NOR” or “NAND” result the same: Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=13 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 Cpu: MT6235BA Flash: toshiba TY8AOA111173KC (12MB) |
what cable you connect mobile,if is P-14H please try P-12C will ok |
as i said in 2nd post above, i use P-12C. |
post result br: ernie78 |
