AVATOR BOX (China Phones Service Tool) |
07-06-2011, 16:31 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 73
Member: 157657 Status: Offline Thanks Meter: 70 | Need explenation. (Answered) This set totally dead,and I found log: ]Initializing... DA_LIB_VER_3.3.4.5 It is sensing the pinout fast,please hold on the phone Power key RXD=13 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 I think that it was hardware problem, cpu or flash ic. But I need explenation about that logs. |
07-06-2011, 16:46 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Hi Check Your Cable Or Jack If They Are Perfect Than It Is Bad Flash Ic. Check Here : http://forum.gsmhosting.com/vbb/7221705-post16.html BR AvatorBox Team |
07-06-2011, 16:57 | #3 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: AvatorBox MCU
Member: 1427447 Status: Offline Sonork: 100.1596998 Thanks Meter: 4,218 | Hi What Version you Are using ? As per your logs . you are using old Version. Always Use Latest Version Regards Avatorbox Quote:
The Following 2 Users Say Thank You to Avatorbox For This Useful Post: |
07-07-2011, 08:08 | #4 (permalink) |
Member: 157657 Status: Offline Thanks Meter: 70 | i use ver5.400. cable was ok (JIG: P-12C), last week i've already fix the same type of phone. but the owner said that the set was repair by other technisian before. and after disassembly, i found much flux in it, so maybe they overheat ic, and make it damage. i will try using ver5.510 and post result. thnx for atention.! btw i have 3 china boxes, avator is new one for me, but after test, avator detected tx/rx very fast than the other. good tools.! Last edited by tomlat; 07-07-2011 at 08:15. |
The Following User Says Thank You to tomlat For This Useful Post: |
07-07-2011, 10:12 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
07-08-2011, 07:12 | #6 (permalink) |
Member: 157657 Status: Offline Thanks Meter: 70 | try version 5.510 and using every boots version but still same. I’m think that’s h/w problem, but need to know for sure, which part was damage, cpu or flash. Tick on “NOR” or “NAND” result the same: Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=13 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 Cpu: MT6235BA Flash: toshiba TY8AOA111173KC (12MB) |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
