03-21-2012, 23:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | 6303c. cannot read with UFS or JAF(SOLVED) when I try to read log, I get an error when reading with a JAF or UFS box. tried on both boxes -------------------------------------- Software version: 1.2.1 Detected card sn: 8EFxxxxxxxxx Card version: 01.00 Life counter: 92.94% Fenix Reader SW version: 0.0.2 Connection interface is set to USB now. Connecting to UFS2 SarasSoft #1 (SN: xxxxx) UFxBoot V2.2 (c) SarasSoft 2003 UFS_USB V2.8 (c) SarasSoft 2007 Connected to UFS interface. Connection interface is set to UFS now. Job's finished successfully! Checking connection... Powering on the phone Reading phone info Product type: RM-443 MCU SW Version: V 08.90 30-06-09 RM-443 (c) Nokia PPM Version: V 08.90 30-06-09 RM-443 (c) Nokia CTM Content Pack Version: Content: c_uk_steel T-Mobile UK 30-06-09 RM-443 (c) Nokia Imei: 35150504xxxxxxx Product code: 0586654 Simlock status: Profile bits: 8000000000000000 Config key: 2343000000000000 Fbus codes typed: 0/10 Key codes typed: 1/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 23 43 0F Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started Setting flash mode Reading CMT boot data... Cannot get phone boot info. Please make sure that phone is connected and you are using a high quality cable Job's finished with errors! ---------------------------------------------------- Can the cable be modified to ensure that the phone is read ? |
03-22-2012, 02:42 | #2 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 594881 Status: Offline Thanks Meter: 77 | yes.... try adding two 7.5k resistors connected to ground and positive terminal of phone.. maybe fenix will add this to their next update,... if there is any. other tools can read the hash of this phone via usb only.... |
03-24-2012, 12:08 | #6 (permalink) |
No Life Poster Join Date: Jan 2005 Location: falcon box
Member: 106346 Status: Offline Sonork: 100.1577684 Thanks Meter: 1,061 | there is a short resistance between mbus 1 and mbus 2 search for cable pinout and do the simple modification as done in 7230 thread here in this section |
03-30-2012, 04:41 | #10 (permalink) | |
Member: 594881 Status: Offline Thanks Meter: 77 | Quote:
yes.... you already had the pinout and modification in your posted pic.... can you not still understand where to place the wires and resistors?? just analyze the connection and youll figure it out... | |
04-12-2012, 09:45 | #12 (permalink) |
Member: 106346 Status: Offline Sonork: 100.1577684 Thanks Meter: 1,061 | i have try to get the phone and use with 6303c but there is different between 6303c and 6303ci cable different here is log on rm-443 Checking connection... Powering on the phone Reading phone info Product type: RM-443 MCU SW Version: V 08.90 30-06-09 RM-443 (c) Nokia PPM Version: V 08.90 30-06-09 RM-443 (c) Nokia CVF Content Pack Version: Content: c_steel VODAFONE IE 30-06-09 RM-443 (c) Nokia Imei: 351505044668260 Product code: 0588117 Simlock status: Profile bits: 8000000000000000 Config key: 2720100000000000 Fbus codes typed: 0/10 Key codes typed: 1/3 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 27 20 1F Analyzing profile bits... This phone can be unlocked via keyboard and fbus Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started Setting flash mode Reading CMT boot data... CMT Boot Data -------------- Asic ID : 000000010000022600010006030C192101033000 Public ID : 134000043C2A8E5649D8172C9165431362525457 Hash : 9DDBFCFE6E73CED7D8C6268C8EB85723 Hardware ID: 030C192101033000 Sending 2ND... Initializing... Booting loader... Reading secure data... Powering the phone Reading phone data Job's finished successfully! br matcom gsm |
04-12-2012, 10:11 | #14 (permalink) |
Member: 43802 Status: Offline Thanks Meter: 36 | There also seems to be two resistors connected to the GND and BSI as seen below Not sure what modifications I need to do according to the picture that I have of my cable. I have ordered another cable from GPG, but that will take another week or so, but I would love to get this one working if possible |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
