10-03-2003, 17:23 | #1 (permalink) |
Junior Member Join Date: Apr 2003
Member: 26320 Status: Offline Thanks Meter: 0 | how to modify the flash file to unprotect it?? I have flashed the Trium Mars with two flashes (one of them is the original), but it no turns up, i think that it is because the flashes are protected, mabe be?? I whould unprotect it but i donīt could edit the file in hex format. Can anybody tell me what program can i use for it?? Another ask: In the IPL 2.90 program, to flash the phone, for what is the option of: "loader file" (ithumb.bin, agent.bin, iarm.bin)???? thanks alot! |
10-03-2003, 18:56 | #2 (permalink) |
Insane Poster Join Date: Aug 2003
Member: 36752 Status: Offline Thanks Meter: 0 | With IPL just select product and it selects the agent itself. I use like HEDIT but there are a LOT of hex editors out there, a lot of them free. See if there is a 2 BYTE: CD AB in the file. Thats the deprotection code. from balu dark. IN FLASH FILE FIND THIS SEQUENSE (FIND WITH FIRST 4 BYTE OF THEM) 1C 00 9F E5 B0 00 D0 E1 AB CC 40 E2 CD 00 5C E3 01 00 00 0A 01 00 A0 E3 00 00 00 EA 00 00 A0 E3 1E FF 2F E1 XX XX XX XX LO .. .. HI XX XX XX XX ADRESS OF CD AB SEQUENSE(END OF FLASH PROTECT) YOU MUST CHANGE LOW BYTE TO 00 AND YOU GET ADRESS OF FLASH PROTECT! FOR EXAMPLE: YOU FIND STRING AND AFTER 2F E1 YOU SEE: B6 50 14 00 AFTER SWAP BYTE ORDER YOU GET ADRESS: 001450B6 (SHORT-1450B6) AT THIS ADRESS YOU PUT 2 BYTE: CD AB AFTER YOU CHANGE LOW BYTE TO 00 AND GET ADRESS 145000 FROM 145000 TO 1450B5 YOU PUT FF BYTE(AS I KNOW IT NOT CHECK !) SO CHANGE TO FF BYTE NOT NESSESARY |
10-03-2003, 19:29 | #3 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Scara Brae
Member: 12623 Status: Offline Thanks Meter: 5 | @Kevin perez Protected flash will just cause "permanently blocked" message. In your case it looks like you read flash with that poor reader that everybody use here - it produces inexact results most times and you have damaged backups. Try downloading good working flash backup and writing it to phone |
10-05-2003, 21:41 | #5 (permalink) |
Member: 12623 Status: Offline Thanks Meter: 5 | @spectrum I don't know (i use my own ), just warned about possible damage from that tool. Try reading many times and comparing results before trying to write that readout. Or just download tested/factory flashes somewhere - f.e. as i remember all flashes from gengheraenga.net that i tried were good |
10-06-2003, 11:49 | #6 (permalink) |
Member: 26320 Status: Offline Thanks Meter: 0 | Hi, Zanzamar! i have a buckup of the original flash, but may be it is corroed, but i have flashed the phone with other flashes from the net, and it doesnīt works, It doesnīt turns on... Know anybody what is my problem and solution??? (it isnīt a hardware problem because before flashing it, them works..) thanks a lot |
because they have not risen to support the flash files to send | residentdenuevo | Infinity-Box | 2 | 07-30-2010 14:39 |
Regarding VPL files [How to modify a VPL file to extract The variant when you can't] | ptt | Cyclonebox | 2 | 01-03-2010 16:19 |
How to use the DIV2UFS to convert the flash file for T610? | hooi76 | UFS2 + UFS3-Tornadoflasher | 0 | 02-20-2008 11:58 |
How to modify a flash file | spider-man | GSM Programming & Reverse Engineering | 8 | 07-13-2007 16:09 |
Is it possible to revise the sbn file to enable the message report on T28s? need help | subaru | Old Ericsson Phones & Sony Phones | 0 | 10-05-2003 01:27 |
