03-21-2014, 11:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: phillippines
Member: 295944 Status: Offline Thanks Meter: 194 | Cherry Mobile BURST " DEADBOOT " revive done by Medusa Jtag TOOLS: MEDUSA BOX USB CABLE CA-101 BOOT FILES DOWNLOAD HERE: Auto Boot 19-12-2013 12_45_09.bin PROCEDURE: - Soldered pinout then connect phone to Box - Connect phone to pc using CA-101 usb cable PINOUT USE: - run MEDUSA software - click CONNECT - browse Auto Boot 19-12-2013 12_45_09 - Flashing Progress . . . . . . Finish DONE JTAG AND PHONE IS ALIVE BUT HANG ONLY ON BURST LOGO NOW PROCEED TO FLASHING - power off phone with battery - hold volume up then press power switch on to put in DOWNLOADING MODE - connect Phone to PC using USB cable CA-101 - Run " Android_AIO_Flasher " download here: Android_AIO_Flasher_1.40 - click RECOVERY on select partition - click SELECT FILE " a28.img " - put check ERASE - then click FLASH - after Flashing " a28.img " download here: a28.img - remove phone to PC and remove battery - now we need atleast 1GB SD card then copy this file " TeamBURST.Rom.mk.4 " download here : TeamBURST.Rom.mk.4.zip in SD card root directory - then put the SD card to power off Phone with battery - hold volume down then press power to enter recovery mode - select " install zip from sdcard " then press power switch to select - select " choose zip from sdcard " then press power switch to select - select " TeamBURST.Rom.mk.4.zip " press power switch to select - select " YES - install TeamBURST.Rom.mk.4.zip " press power switch to select then Follow procedure in Phone screen . . . and wait till finish Flashing via SD card FINISH FLASHING VIA SD CARD Thanks and Credits Goes to my GSM friends for iDeas , Firmwares and Procedures. jaded_17 ayhen42 etnad Br, Xeven2nd |
The Following 11 Users Say Thank You to 7even2nd For This Useful Post: |
03-21-2014, 11:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Thank You for such detailed step-by-step manual and report. Please upload somewhere also clear photo of phone's PCB in HQ, we will add this device in next Software update. |
