09-27-2022, 08:40 | #4 (permalink) |
Junior Member Join Date: Jan 2019 Location: Algeria Age: 43
Member: 2889780 Status: Offline Thanks Meter: 3 | operation smart repair Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/OPPO_A3S_CPH1803_EMMC_ISP_BY_PIJUSH_DAS.srf". Write data verification is enabled. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switch error!!! Writing GPT partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Switched to user area. Writing oppodycnvbk partition... Done. Writing oppostanvbk partition... Done. Writing persist partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing opporeserve1 partition... Done. Writing opporeserve2 partition... Done. Writing reserve_exp1 partition... Done. Writing reserve_exp2 partition... Done. Writing fsc partition... Done. Writing ssd partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing sbl1 partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing devcfg partition... Done. Writing sbl1bak partition... Done. Writing rpmbak partition... Done. Writing tzbak partition... Done. Writing devcfgbak partition... Done. Writing dsp partition... Done. Writing DDR partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing sec partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing modem partition... Done. Writing dtbo partition... Done. Writing vbmeta partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing devinfo partition... Done. Writing splash partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing LOGO partition... Done. Writing DRIVER partition... Done. Writing cache partition... Done. Writing keystore partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing config partition... Done. Writing oem partition... Done. Writing limits partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing mota partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing dip partition... Done. Writing mdtp partition... Done. Writing syscfg partition... Done. Writing mcfg partition... Done. Writing lksecapp partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing cmnlib partition... Done. Writing cmnlib64 partition... Done. Writing keymaster partition... Done. Writing lksecappbak partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64bak partition... Done. Writing keymasterbak partition... Done. Writing apdp partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing logdump partition... Done. Writing vm-kystore partition... Done. Writing vm-data partition... Done. Writing hyp partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Writing vm-system partition... Done. Writing vm-linux partition... Done. Smart Repair is successfully complete. SW: 2.2.4.7; FW: 1.24. Disconnected. |
09-27-2022, 14:22 | #7 (permalink) |
Member: 2889780 Status: Offline Thanks Meter: 3 | Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803_32GB SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/OPPO_A3S_CPH1803_EMMC_ISP_BY_PIJUSH_DAS.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A5C0C9EEE91647 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.5 Product serial number : (hex) C0C9EEE9 Manufacturing date : 01/2019 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4a2_27_09_2022_14_19_53.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.7; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 01299FDF) 9.301 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4a2_modemst1_0xa028_0xc00_27_09_2022_14_19_53.b in file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.4.7; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4a2_modemst2_0xac28_0xc00_27_09_2022_14_19_53.b in file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.4.7; FW: 1.24. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4a2_fsg_0x50040_0xc00_27_09_2022_14_19_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.4.7; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 2064384 Number of sectors : 7030784 Device Manufacturer : OPPO Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20210122.143520 release-keys --------------------------------------------------------------- Selected file: C:/Users/pc/Downloads/Nouveau dossier/rawprogram0.xml Selected rawprogram XML file: C:/Users/pc/Downloads/Nouveau dossier/rawprogram0.xml. Switched to user area. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. Writing. Please wait... Write data verification is enabled. Writing partition oppodycnvbk... Read verification error 1. Possible reasons: flash memory damaged or write protected. Disconnected. Please disconnect battery and USB cable. |
09-29-2022, 17:46 | #8 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | Code: ERROR[012]: Write error. Writing DDR partition... 2- Write EXT_CSD 3- Check Partition "config : (0x38) 00111000" 4- Smart Repair Use "OPPO_A3S_EMMC.SRF" 5- Oppo A3s CPH 1853 Imei Null Unknown Basband Fix Without Flashing |
The Following User Says Thank You to DZGSM-TEAM For This Useful Post: |
