06-18-2020, 20:37 | #1 (permalink) |
Insane Poster Join Date: Jan 2014 Location: Algérie
Member: 2105490 Status: Offline Thanks Meter: 29 | A dead wiko jerry still dead after boot repair Before repairs Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC M MOR Page size : 512 B Block size : 512 B Block count : 3848192 Size : 1879.00 MB --------------------------------------------------------------- CID Info CID : 65646F4D204D4F5212A100000240012F Manufacturer ID : 0X65 Device/BGA : Device (removable) OEM/Application ID : 0X6F Product name : M MOR Product revision : 10.1 Product serial number : (hex) 240 Manufacturing date : 00/2014 --------------------------------------------------------------- CSD Info CSD : D07FFF320F59007FF6DB80001E40001D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 131072 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M MOR_15_06_2020_17_16_48.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- After repair Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384731650500000000000045 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.0 Product serial number : (hex) 0 Manufacturing date : 00/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G1e_18_06_2020_17_58_35.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Switched to boot area partition 1. Erasing. Please wait... Done. SW: 2.1.1; FW: 1.24. Switched to boot area partition 2. Erasing. Please wait... Done. SW: 2.1.1; FW: 1.24. Switched to user area. Erasing. Please wait... Done. SW: 2.1.1; FW: 1.24. --------------------------------------------------------------- Selected scatter file: C:/Users/P/Desktop/MT6580__WIKO__JERRY__V2802AN__6.0__ALPS.W10.24.p0/MT6580_Android_scatter.txt. Scatter file type 2. Opened input file: C:/Users/P/Desktop/MT6580__WIKO__JERRY__V2802AN__6.0__ALPS.W10.24.p0/preloader_v2802.bin Found 3 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : F822MB eMMC CID : 150100463832324D42 eMMC Vendor ID : 45 (Sandisk eMMC) eMMC Model ID : 0001 eMMC Name : DS1008 eMMC CID : 450100445331303038 eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : H8G1e eMMC CID : 90014A483847316505 Writing. Please wait... Switched to boot area partition 1. Writing partition preloader... Write data verification is enabled. Done. Switched to user area. Writing partition lk... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition logo... Done. Writing partition ewdata... Done. Writing partition apedata... Done. Writing partition secro... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition userdata... Done. Writing checksums...Done. Writing finished. SW: 2.1.1; FW: 1.24. Disconnected. |
The Following 2 Users Say Thank You to billymore For This Useful Post: |
