12-18-2019, 20:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Poland Age: 47
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | emmc 186 problem [Answered] Reading. Please wait... ERROR[011]: Read error. At sector 0 Attempting to read... Disconnected. now, when I try to read it again, memory isn't recognized, and software shows me afterwhile Connecting... ERROR[001]: Can not connect. No target device present. And I have in program status BOX status: not connected. Any help? here is the log: Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC M MOR Page size : 512 B Block size : 512 B Block count : 3848192 Size : 1879.00 MB --------------------------------------------------------------- CID Info CID : 65646F4D204D4F521281000002400153 Manufacturer ID : 0X65 Device/BGA : Device (removable) OEM/Application ID : 0X6F Product name : M MOR Product revision : 8.1 Product serial number : (hex) 240 Manufacturing date : 00/2014 --------------------------------------------------------------- CSD Info CSD : D07FFF320F59007FF6DB80001E40001D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 131072 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M MOR_18_12_2019_20_46_55.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.0; FW: 1.24. Opening C:/Program Files (x86)/Medusa Pro Software/Unknown eMMC M MOR_18_12_2019_20_47_17.bin file... Reading. Please wait... ERROR[011]: Read error. At sector 0 Attempting to read... Disconnected. |
12-18-2019, 22:49 | #2 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | Quote:
See logs: Code: Device : Unknown eMMC M MOR Page size : 512 B Block size : 512 B Block count : 3848192 Size : 1879.00 MB --------------------------------------------------------------- CID Info CID : 65646F4D204D4F521281000002400153 Manufacturer ID : 0X65 Device/BGA : Device (removable) OEM/Application ID : 0X6F Product name : M MOR Product revision : 8.1 Product serial number : (hex) 240 Manufacturing date : 00/2014 | |
