06-12-2017, 09:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | G532g boot repair done Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A483847347592010F95A04544B5 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) F95A045 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer : samsung Device Platform : mt6737t Build ID : MMB29T Display Build ID : MMB29T.G532GDXU1APL1 Release ID : 6.0.1 Device Model : SM-G532G Device Name : grandppltedx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : grandppltedx-user 6.0.1 MMB29T G532GDXU1APL1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_12_06_2017_13_57_28.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.8; FW: 1.18. P00: GPT (00000000, 00002000) P01: BOTA0 (00002000, 00002000) P02: nvram (00004000, 00004000) P03: lk (00008000, 00001000) P04: BOTA1 (00009000, 00001000) P05: secro (0000A000, 00003800) P06: seccfg (0000D800, 00000400) P07: efuse (0000DC00, 00000400) P08: tee1 (0000E000, 00003000) P09: BOTA2 (00011000, 00003000) P10: EFS (00014000, 00004000) P11: nvdata (00018000, 00010000) P12: PARAM (00028000, 00004000) P13: recovery (0002C000, 00008000) P14: boot (00034000, 00008000) P15: md1img (0003C000, 00010000) P16: md1dsp (0004C000, 00002000) P17: keystore (0004E000, 00004000) P18: omekeystore (00052000, 00001C00) P19: proinfo (00053C00, 00001400) P20: para (00055000, 00000400) P21: PERSISTENT (00055400, 00000400) P22: STEADY (00055800, 00000800) P23: protect1 (00056000, 00004000) P24: protect2 (0005A000, 00004000) P25: RESERVE2 (0005E000, 00002000) P26: system (00060000, 00604000) P27: cache (00664000, 000C8000) P28: hidden (0072C000, 0001E000) P29: userdata (0074A000, 00744000) Selected pit file: D:/MEDUSA PRO/MEDUSA BOOT FILE/G532G REPAIR FILE/GRANDPPLTE_CIS_SER.pit Open file "D:/MEDUSA PRO/MEDUSA BOOT FILE/G532G REPAIR FILE/BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to user area. Writing partition lk... Done. Writing partition efuse... Done. Writing partition tee1... Done. Writing partition PARAM... Done. Writing is finished. SW: 1.3.8; FW: 1.18. |
The Following 4 Users Say Thank You to rohit.sharma73 For This Useful Post: |
