Member: 1082907
Sonork: 100.1606954 Thanks Meter: 342 | GT-N8020 after update eMMC dead [Answered] this tab come to me on stuck on logo when i ve flash any thing odin always fail
then connect emmc pinout and found write protection on emmc
after remove protection i ve deside update emmc so after update emmc write extcsd backup then write full firmware with pit file but after write firmware tab not on also not going in to doenload mode
here is log Quote:
Welcome to Medusa Pro Software version 1.5.8.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: FT SCR2000 0
Reader #2: FT SCR2000 1
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC MAG2GA
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 1501004D414732474107B2B84D3DAF41
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : MAG2GA
Product revision : 0.7
Product serial number : (hex) B2B84D3D
Manufacturing date : 10/2012
CSD Info
CSD : D02701320F5903FFF6DBFFFF8A406063
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : YES
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.5 (for MMC v4.41)
Erase block size : 512 Kbytes
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 128 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7659520 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 2940928
Number of sectors : 3145728
Device Manufacturer :samsung
Device Platform :exynos4
Build ID :KOT49H
Display Build ID :KOT49H.N8020XXUDOH1
Release ID :4.4.2
Device Model :GT-N8020
Device Name 4noteltexx
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Build Description 4noteltexx-user 4.4.2 KOT49H N8020XXUDOH1 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_17_40.bin.
Connect successful.
SW: 1.5.8; FW: 1.23.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: BOTA1 (00004000, 00002000) 4 MB
P03: EFS (00006000, 0000A000) 20 MB
P04: m9kefs1 (00010000, 00002000) 4 MB
P05: m9kefs2 (00012000, 00002000) 4 MB
P06: m9kefs3 (00014000, 00002000) 4 MB
P07: PARAM (00016000, 00004000) 8 MB
P08: BOOT (0001A000, 00004000) 8 MB
P09: RECOVERY (0001E000, 00004000) 8 MB
P10: RADIO (00022000, 0002C000) 88 MB
P11: TOMBSTONES (0004E000, 00080000) 256 MB
P12: CACHE (000CE000, 00200000) 1024 MB
P13: SYSTEM (002CE000, 00300000) 1536 MB
P14: HIDDEN (005CE000, 00118000) 560 MB
P15: OTA (006E6000, 00004000) 8 MB
P16: USERDATA (006EA000, 0166E000) 11.21 GB
Remove write protect successfully completed.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
CSD : D02701320F5903FFF6DBFFFF8A404007
TRAN speed : 26 MHz
PERM_WRITE_PROTECT : NO
EXTCSD Info
(Bus width = 4Bit)
Ok
Build ID :KOT49H
Release ID :4.4.2
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_18_38.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Ok
Build ID :KOT49H
Release ID :4.4.2
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_27_50.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Ok
Build ID :KOT49H
Release ID :4.4.2
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_28_39.bin.
Connect successful.
Factory Format will erase all eMMC data!
Do you want to continue? No.
Writing eMMC firmware from file: C:/Program Files (x86)/Medusa Pro Software/EMMC_firmwares/KLMAG2GE4A-A002/KLMAG2GE4A-A002_FW.bin...Done.
Finalizing...Done.
Changing CID to 1501004D414732474105C8049C3A5F37.
Write CID succesfully completed.
Disconnected.
EMMC writing firmware Done.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC 000000
Page size : 512 B
Block size : 512 B
Block count : 33554432
Size : 16.00 GB (16384.00 MB)
CID Info
CID : 1501003030303030305620110726589D
Product name : 000000
Product revision : 5.6
Product serial number : (hex) 20110726
Manufacturing date : 05/2021
CSD Info
CSD : 902701320F5903FFF6DBFFEF8A404023
TRAN speed : 26 MHz
EXTCSD Info
Boot1 size : 512 Kbytes
Boot2 size : 512 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Max enhanced data size: 4026531840 Kbytes
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_08_05_2018_08_29_30.bin.
Connect successful.
Finalizing...Done.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CID : 1501004D414732474105C8049C3A5F37
Product revision : 0.5
Product serial number : (hex) C8049C3A
Manufacturing date : 05/2012
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_30_55.bin.
Connect successful.
Writing EXT_CSD succesfully complete!
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_33_12.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_36_57.bin.
Connect successful.
Selected pit file: C:/Users/Faizan/Desktop/N8020XXUDOH1_N8020TELDOH1_TEL/N8020XXUDOH1_N8020TELDOH1_N8020DVUDOG1_HOME.tar.md 5
Unknown format of input file C:/Users/Faizan/Desktop/N8020XXUDOH1_N8020TELDOH1_TEL/N8020XXUDOH1_N8020TELDOH1_N8020DVUDOG1_HOME.tar.md 5!
Partition table was not found.
Selected pit file: C:/Users/Faizan/Desktop/note10lte_secure_boot.pit
Open file "C:/Users/Faizan/Desktop/N8020XXUDOH1_N8020TELDOH1_N8020DVUDOG1_HOME.tar.md 5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT
Write data verification is enabled.
Writing. Please wait...
Switched to boot area partition 1.
Writing partition BOOTLOADER... Done.
Writing partition TZSW... Done.
Switched to user area.
Writing partition BOOT... Done.
Writing partition RECOVERY... Done.
Writing partition RADIO... Done.
Writing is finished.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_08_43_08.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_09_13_34.bin.
Connect successful.
Please select file.
Please select file.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_09_14_58.bin.
Connect successful.
Smart report info:
Hash code: F30D13F3138D8A3BEB22770F370E096BE2FA65747EE1BA99EB DA64CE930CC7E2
Super block size : 0x00800000 Bytes
Super page size : 0x00008000 Bytes
Optima write size : 0x00010000 Bytes
Number of banks : 2
Bank0 init bad block : 2
Bank0 runtime bad block : 0
Bank0 remain reserved block : 49
Max erase count : 1
Min erase count : 0
Avg erase count : 0
Read reclaim count : 0
Optimal trim size : 0x00002000 Bytes
Max erase count (SCL) : 1
Min erase count (SCL) : 0
Avg erase count (SCL) : 0
Max erase count (MLC) : 1
Min erase count (MLC) : 0
Avg erase count (MLC) : 0
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_09_16_42.bin.
Connect successful.
Please select file.
Writing MBR...Done.
Writing PIT
Writing partition CACHE... Done.
Writing partition SYSTEM... Done.
Writing partition HIDDEN... Done.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Ok
Build ID :KOT49H
Release ID :4.4.2
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_08_05_2018_09_33_55.bin.
Connect successful.
| one more thing before update emmc firmware Product revision : 0.7 after update shown Product revision : 0.5
