01-31-2014, 09:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Currenty we have no Full flash for this device. We will try get this device and read Full flash for You in next several days. Now try to make "Factory data reset", "Wipe cache partition" and re-flash the device once again. Also, this can be HW problem. |
01-31-2014, 13:57 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | This can be Software (modem firmware is damaged or written unsuitable firmware) or HW problem. At first, try to re-flash the device with different firmwares and check whether modem is correct (baseband is not Unknown) and only then (when baseband will be correct) perform "Repair IMEI" procedure. It is not possible to repair IMEI, if phone's modem part is damaged. |
