08-02-2021, 13:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | HELP ME REVIVE J100H DEAD while flashing [Answered] Interface : eMMC Brand : Samsung Model : SM-J100H SRF : E:/MEDUSA FIRMWARE/Samsung_SM-J100H_EMMC_H4G2B.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : 50 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A48344732621101464B3D2392BD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 464B3D23 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_02_08_2021_14_19_17.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Repairing from file "E:/MEDUSA FIRMWARE/Samsung_SM-J100H_EMMC_H4G2B.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Smart Repair is successfully complete. SW: 2.2.2; FW: 2.00. Disconnected. Get Measurements error. Reloading... HELP ME NEWBIE |
08-02-2021, 15:50 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please try to connect with next setups: Voltage : 1.8V Bus Mode : 1 bit Bus speed : 6 MHz You can also add 2 pull_up resistors (120 ... 390 Ohm) between the CMD -> VCCQ and D0 -> VCCQ signals as shown in the screenshot. |
