Member: 487336
Thanks Meter: 33 | Help Unlock bootloader a22 5g U5 [Answered] I have a226B U5
i can't unlock bootloader photo_2023-01-03_10-02-39.jpg Quote:
Johnny, [03.01.2023 10:39]
Socket detected!
Selected PIN - CONNECTOR.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting to server. Please wait...
Connection to server successful
Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4)
Connecting...
Device : Samsung eMMC DV6DBB
Page size : 512 B
Block size : 512 B
Block count : 244285440
Size : 116.48 GB (119280.00 MB)
CID Info
CID : 15010044563644424200F8B3D4FF29F7
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : DV6DBB
Product revision : 0.0
Product serial number : (hex) F8B3D4FF
Manufacturing date : 02/2022
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 8Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x02) 00000010
Boot bus width : x8 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 40714240 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DV6DBB_03_01_2023_10_39_29.bin.
Connect successful.
SW: 2.2.4.7; FW: 2.00.
P00: GPT (00000000, 0000A000) 40 KB
P01: md5hdr (0000A000, 003F6000) 4056 KB
P02: efs (00400000, 00800000) 8 MB
P03: sec_efs (00C00000, 00800000) 8 MB
P04: steady (01400000, 00400000) 4 MB
P05: nvdata (01800000, 04000000) 64 MB
P06: protect1 (05800000, 00800000) 8 MB
P07: protect2 (06000000, 00800000) 8 MB
P08: seccfg (06800000, 00800000) 8 MB
P09: nvram (07000000, 04000000) 64 MB
P10: spmfw (0B000000, 00100000) 1024 KB
P11: scp1 (0B100000, 00100000) 1024 KB
P12: sspm_1 (0B200000, 00100000) 1024 KB
P13: uh (0B300000, 00200000) 2048 KB
P14: tee1 (0B500000, 00200000) 2048 KB
P15: tzar (0B700000, 00400000) 4 MB
P16: gz1 (0BB00000, 01000000) 16 MB
P17: lk (0CB00000, 00200000) 2048 KB
P18: dpm_1 (0CD00000, 00100000) 1024 KB
P19: mcupm_1 (0CE00000, 00100000) 1024 KB
P20: dtbo (0CF00000, 00800000) 8 MB
P21: vbmeta (0D700000, 00010000) 64 KB
P22: btd (0D710000, 000F0000) 960 KB
P23: nvcfg (0D800000, 02000000) 32 MB
P24: persist (0F800000, 03000000) 48 MB
P25: bota (12800000, 03400000) 52 MB
P26: boot_para (15C00000, 01A00000) 26 MB
P27: para (17600000, 00080000) 512 KB
P28: misc (17680000, 00080000) 512 KB
P29: expdb (17700000, 02800000) 40 MB
P30: frp (19F00000, 00100000) 1024 KB
P31: metadata (1A000000, 02000000) 32 MB
P32: keyrefuge (1C000000, 01000000) 16 MB
P33: keydata (1D000000, 01000000) 16 MB
P34: persistent (1E000000, 00080000) 512 KB
P35: proinfo (1E080000, 00300000) 3072 KB
P36: md1img (1E380000, 0C800000) 200 MB
P37: pi_img (2AB80000, 00100000) 1024 KB
P38: logo (2AC80000, 00800000) 8 MB
P39: param (2B480000, 00400000) 4 MB
P40: up_param (2B880000, 00400000) 4 MB
P41: boot (2BC80000, 02000000) 32 MB
P42: recovery (2DC80000, 02800000) 40 MB
P43: vbmeta_system (30480000, 00010000) 64 KB
P44: vbmeta_vendor (30490000, 00010000) 64 KB
P45: efuse (304A0000, 00080000) 512 KB
P46: rsv1 (30520000, 002E0000) 2944 KB
P47: sec1 (30800000, 00800000) 8 MB
P48: super (31000000, 1AF800000) 6.742 GB
P49: prism (1E0800000, 2C000000) 704 MB
P50: optics (20C800000, 01800000) 24 MB
P51: cache (20E000000, 0C800000) 200 MB
P52: omr (21A800000, 03200000) 50 MB
P53: spu (21DA00000, 03200000) 50 MB
P54: userdata (220C00000, 1AFE000000) 108 GB
Searching Android build info...
Ok
Disk/Image size : 1f000000 bytes
Device sector size : 512 bytes
Partition offset : 1605632
Number of sectors : 14139392
Build ID : SP1A.210812.016
Display Build ID : SP1A.210812.016.A226BXXU5BVH2
Release ID : 12
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : a22xnsxx-user 12 SP1A.210812.016 A226BXXU5BVH2 release-keys
RPMB: Counter of the successful data write requests = 40.
