Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 08-02-2021, 13:29   #1 (permalink)
Fragga's Avatar
Member: 1507693
Thanks Meter: 131
HELP ME REVIVE J100H DEAD while flashing [Answered]
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J100H
SRF : E:/MEDUSA FIRMWARE/Samsung_SM-J100H_EMMC_H4G2B.srf
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 50 MHz
Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4)
Connecting...
Device : Hynix eMMC H4G2b
Page size : 512 B
Block size : 512 B
Block count : 7634944
CID Info
CID : 90014A48344732621101464B3D2392BD
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H4G2b
Product revision : 0.1
Product serial number : (hex) 464B3D23
Manufacturing date : 09/2015
CSD Info
CSD : D07F01320F5903FFFFFFFFEF8A4040DB
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 80 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 1908736 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_02_08_2021_14_19_17.bin.
Connect successful.
SW: 2.2.2; FW: 2.00.
Searching Android build info...
Not found
RPMB: Authentication Key not yet programmed.
Repairing from file "E:/MEDUSA FIRMWARE/Samsung_SM-J100H_EMMC_H4G2B.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing SBOOT partition... Done.
Writing SBOOT2 partition... Done.
Writing wfixnv1 partition... Done.
Writing wfixnv2 partition... Done.
Writing tdfixnv1 partition... Done.
Writing tdfixnv2 partition... Done.
Writing WDSP partition... Done.
Writing MODEM partition... Done.
Writing MODEM2 partition... Done.
Writing TDDSP partition... Done.
Writing wruntimenv1 partition... Done.
Writing wruntimenv2 partition... Done.
Writing tdruntimenv1 partition... Done.
Writing tdruntimenv2 partition... Done.
Writing PARAM partition... Done.
Writing efs partition... Done.
Smart Repair is successfully complete.
Disconnected.
Get Measurements error. Reloading...
HELP ME NEWBIE
Old 08-02-2021, 15:50   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello.
Please try to connect with next setups:
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : 6 MHz
You can also add 2 pull_up resistors (120 ... 390 Ohm) between the CMD -> VCCQ and D0 -> VCCQ signals as shown in the screenshot.
Page generated in 0.15649 seconds with 8 queries
