04-02-2017, 06:18 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Chile Age: 30
Member: 2432038 Status: Offline Thanks Meter: 108 | Error Server Download /Medusa Pro / Octoplus box [Answered] I have a problem since days with the server of Octoplus box, I just bought jellyfish and I can not download anything from the support, the error shown is the following: Error: Please Try Authorize Again / Medusa Pro and Octoplus Box Last edited by Medusa Box; 04-03-2017 at 08:45. |
04-02-2017, 13:19 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please disable antivirus and firewall (if they are running) and try again. Write here the result. The problem can be also with your Internet connection (some of the necessary ports for connection can be blocked by your ISP). Try to use another Internet connection. If You still can't download SRFs via "Download *.srf" button in Software, You can download it directly from here: https://www.boot-loader.com/eng/medusapro_free_section, from "!SRF for Medusa PRO software" folder. Also You can try to download files using the latest version (1.1.9) of Octopus/Octoplus Shell Software (http://octoplusbox.com/en/download/software/). Note, after direct downloading of SRFs, You need to install them into Software (press "Install custom model file(s)" button at "Welcome" tab in Medusa Pro Software). As a result, model will appear in Software list after SFR installation. Last edited by Medusa Box; 04-03-2017 at 08:44. |
11-13-2020, 15:47 | #3 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2564751 Status: Offline Sonork: Paloma Thanks Meter: 1 | Same issue with Medusa Pro Box 2.1.5 Now issue is card is not supported for downgrade firmwares like 2.1.2 or 2.1.0 . Too bad Is there any way to use down firmwares when card is updated to 2.1.5 |
11-18-2020, 10:07 | #5 (permalink) | |
Member: 2564751 Status: Offline Sonork: Paloma Thanks Meter: 1 | Quote:
This seems a bug in update | |
11-18-2020, 10:22 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | It's not a bug, unfortunately, old versions of Softwares aren't available and aren't suitable with new card firmware versions |
The Following User Says Thank You to Medusa Box For This Useful Post: |
