03-27-2014, 13:51 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 52
Member: 117004 Status: Offline Thanks Meter: 1 | htc wildfires imei repair [Solved] HTC wildfires fullflash_4k.mf or HTC wildfires fullflash_2k.mf model HTC wildfire s NM8PG76100. Last edited by Octopus box; 03-28-2014 at 11:08. |
03-27-2014, 14:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Post here full Software log with the process of Repairing. All logs are saved here: "c:\Program Files\GsmServer\Medusa\Log\". |
03-27-2014, 17:23 | #3 (permalink) |
Member: 117004 Status: Offline Thanks Meter: 1 | Log started at 26.03.2014 11:29:49 ... Welcome to Medusa Box Software version 2.1.8 Operating Mode: EasyRepair Mode Selected device model: HTC Wildfire S (PG76100) Connecting. Please wait... ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. Please connect the target device and power it on... ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. Operating Mode: EasyRepair Mode Selected device model: HTC Wildfire S (PG76100) Connecting. Please wait... MI: RTCK reaction time 7788 ns, average speed 128 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 203C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.74 V CPU : Qualcomm MSM7227T Core ID : 203C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0x0000F00F, cycle 1. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA0AD55BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: Hynix H8BES0UQ0MCR Flash ID : 00AD55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. HTC CID : T-MOB005 IMEI : 358968-04-044734 Opening "C:\Program Files\GsmServer\Medusa\Firmware\HTC_WILDFIRES_Repa ir.mf" file... Writing BOOT2 section. Please wait... Done Writing APPBOOT2 section. Please wait... Done Repairing CID and IMEI... Done Disconnected Repair done. Connecting to server Retrieving files list Connecting to server Retrieving files list |
03-28-2014, 08:12 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Most likely, your device was locked before You have performed Repair procedure. Try to Read unlock code and enter it to unlock the device. Please look here: http://forum.gsmhosting.com/vbb/8350204-post337.html, http://forum.gsmhosting.com/vbb/f664...2/#post8340831, http://forum.gsmhosting.com/vbb/f664...7/#post8142914. |
03-28-2014, 11:03 | #5 (permalink) |
Member: 117004 Status: Offline Thanks Meter: 1 | Operating Mode: Advanced Mode Selected device model: HTC Wildfire S (PG76100) Connecting. Please wait... MI: RTCK reaction time 138001 ns, average speed 7 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 203C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.73 V CPU : Qualcomm MSM7227T Core ID : 203C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0x0000F00F, cycle 1. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA0AD55BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: Hynix H8BES0UQ0MCR Flash ID : 00AD55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. HTC CID : T-MOB005 IMEI : 357052-00-231381 Connect successful. Reading codes. Please wait... NCK Code : 64637832 thank you |
