12-03-2018, 14:57 | #1 (permalink) |
Freak Poster Join Date: Feb 2013 Location: algeria
Member: 1882912 Status: Offline Sonork: 100.1677703 Thanks Meter: 263 | LG-M250E repair boot question [Answered] here log Code: Welcome to Medusa Pro Software version 1.7.0. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : M250E SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_M250E_EMMC_BY_STARKRIMES.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A432402E3DB471 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 32402E3D Manufacturing date : 11/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1179648 Number of sectors : 8126464 Device Manufacturer :lge Device Platform :mt6750 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-M250 Device Name :mlv5_global_com Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :mlv5_global_com-user 7.0 NRD90U 180112204be56 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4a2_03_12_2018_10_48_01.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.0; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: spare1 (00001C00, 00002400) 4.5 MB P03: misc2 (00004000, 00004000) 8 MB P04: ftm (00008000, 00004000) 8 MB P05: nvram (0000C000, 00002800) 5 MB P06: spare2 (0000E800, 00001800) 3072 KB P07: protect1 (00010000, 00004000) 8 MB P08: protect2 (00014000, 00004000) 8 MB P09: lk (00018000, 00000800) 1024 KB P10: lk2 (00018800, 00000800) 1024 KB P11: laf (00019000, 0000E000) 28 MB P12: para (00027000, 00000400) 512 KB P13: boot (00027400, 00008C00) 17.5 MB P14: recovery (00030000, 00009800) 19 MB P15: recoverybak (00039800, 00009800) 19 MB P16: logo (00043000, 00004000) 8 MB P17: lo_bak_go (00047000, 00004000) 8 MB P18: expdb (0004B000, 00005000) 10 MB P19: seccfg (00050000, 00004000) 8 MB P20: oemkeystore (00054000, 00004000) 8 MB P21: secro (00058000, 00003000) 6 MB P22: spare3 (0005B000, 00001000) 2048 KB P23: keystore (0005C000, 00004000) 8 MB P24: tee1 (00060000, 00002800) 5 MB P25: tee2 (00062800, 00002800) 5 MB P26: eksst (00065000, 00000400) 512 KB P27: encrypt (00065400, 00000400) 512 KB P28: spare4 (00065800, 00002800) 5 MB P29: persist_lg (00068000, 00004000) 8 MB P30: mpt (0006C000, 0000B000) 22 MB P31: lgfota (00077000, 00005000) 10 MB P32: rct (0007C000, 00000800) 1024 KB P33: factory (0007C800, 0001C000) 56 MB P34: efuse (00098800, 00000400) 512 KB P35: spare5 (00098C00, 00003400) 6.5 MB P36: persist (0009C000, 00018000) 48 MB P37: nvcfg (000B4000, 00004000) 8 MB P38: nvdata (000B8000, 00010000) 32 MB P39: metadata (000C8000, 00010000) 32 MB P40: md1img (000D8000, 0000C000) 24 MB P41: md1dsp (000E4000, 00002000) 4 MB P42: md1arm7 (000E6000, 00001800) 3072 KB P43: md3img (000E7800, 00002800) 5 MB P44: cust (000EA000, 00032000) 100 MB P45: frp (0011C000, 00004000) 8 MB P46: system (00120000, 007C0000) 3968 MB P47: cache (008E0000, 00100000) 512 MB P48: OP (009E0000, 00038000) 112 MB P49: userdata (00A18000, 0133BC00) 9.617 GB P50: flashinfo (01D53C00, 00008000) 16 MB first one SAMSUNG EMMC QE13MB already in support eria 2end Hynix eMMC HAG4a2 i tried Factory repair using this firmware M250E10g_00_OPEN_AME_DS_OP_0427 phone still dead Code: Parsing file... Opening H:/M250E10g_00_OPEN_AME_DS_OP_0427.kdz file... File parsing finished. Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition preloader... Done. Switched to user area. Writing partition pgpt... Done. Writing partition lk... Done. Writing partition lk2... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition logo... Done. Writing partition secro... Done. Writing partition tee1... Done. Writing partition tee2... Done. Writing partition rct... Done. Writing partition factory... Done. Writing partition efuse... Done. Writing partition md1img... Done. Writing partition md1dsp... Done. Writing partition md1arm7... Done. Writing partition md3img... Done. Writing partition cust... Done. Writing partition sgpt... Done. Switched to user area. Writing partition OP_T... Done. Writing is finished. SW: 1.7.0; FW: 1.24. #blue Last edited by Medusa Box; 12-03-2018 at 15:25. |
12-03-2018, 15:24 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Try to use V20x original firmware versions for "Factory Repair" (https://lg-firmwares.com/lg-m250e-firmwares/firmwares/). |
