ls991 repari emmc done but after flash now on QHSUSB_DLOAD help ls991 was stuck on logo tried to flash with octopus but flashing failed then i repair emmc with medusa pro Quote:
hi Team i also Have LS991---10 pcs in hand . i need latest Repair/KDZ File bcoz all handsets was Dead Bcoz Of Downgrade i tried smart repair and Charles File Both Method but Still The Same : Its Stuck on QCOM 9008. |
Hi. @ Ismail khan1978 Try to make Factory Repair using different original firmwares for LG LS991. @ XpErTsGsM Quote:
@ Ismail khan1978 and @ XpErTsGsM Please check your PM, we have sent You few links to firmwares. Try to make Factory Repair using these firmwares and then post here the result. |
thank you for your reply my internet was not working from last 2 days now its OK :D i m downloading your provided files and will report you |
i flashed with this file but same (LS991ZV6_12_ARB02.tot) Quote:
(LS991ZVB_02_ARB03.tot) Quote:
Most likely, Your device has HW problem, You have to take into account that a common problem in this model exists - manufacturer's hardware issue which leads to MCU overheat and QC mode falldown. In some cases reballing did help, but mostly - only MCU exchange could solve the problem. |
ok thank you its my bad luck i think its manufacturer fault thank you for your kind help |
