ls991 was stuck on logo
tried to flash with octopus but flashing failed
then i repair emmc with medusa pro
Please disconnect battery and USB cable.
Selected device model: LG LS991.
Selected file: C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_LS991_EMMC_032G74.srf.
eMMC interface selected.
Connecting...
Device : Toshiba eMMC 032G74
Page size : 512 B
Block size : 512 B
Block count : 61071360
CID Info
CID : 11010030333247373400C74620B342C9
Manufacturer ID : 0X11
Device/BGA : BGA(Discrete embeded)
OEM/Application ID : 0X00
Product name : 032G74
Product revision : 0.0
Product serial number : (hex)C74620B3
Manufacturing date : 04/2015
CSD Info
CSD : D02700320F5903FFFFFFFFE78640009B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Boot partition enable : Device not boot enabled (default)
Partition config : 00000000
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/032G74_13_11_2016_13_33_34.bin.
Connect successful.
Erasing. Please wait... Done.
SW: 1.2.3; FW: 1.14.
Switched to UA!!!
Writting GPT partition... Done.
Writting pmic partition... Done.
Writting sbl1 partition... Done.
Writting tz partition... Done.
Writting sdi partition... Done.
Writting hyp partition... Done.
Writting rpm partition... Done.
Writting aboot partition... Done.
Writting limits partition... Done.
Writting devinfo partition... Done.
Writting apdp partition... Done.
Writting msadp partition... Done.
Writting dpo partition... Done.
Writting spare1 partition... Done.
Writting misc partition... Done.
Writting persist partition... Done.
Writting modemst1 partition... Done.
Writting modemst2 partition... Done.
Writting fsg partition... Done.
Writting fsc partition... Done.
Writting ssd partition... Done.
Writting keystore partition... Done.
Writting DDR partition... Done.
Writting sec partition... Done.
Writting encrypt partition... Done.
Writting eksst partition... Done.
Writting rct partition... Done.
Writting persistent partition... Done.
Writting laf partition... Done.
Writting boot partition... Done.
Writting recovery partition... Done.
Writting raw_resources partition... Done.
Smart Repair is successfully complete.
Disconnected |
after emmc repair now set is flashed but now on QHSUB_DLOAD
Welcome to Octoplus/Octopus Box LG Software version 2.4.9.1
Platform: LG Qualcomm
Selected port: COM85
Selected model: LS991
Reading info...
Model ID: LGLS991
IMEI: 357355-06-232631-6
Android version: 5.1
Battery level: 39%
SW Version: LS991ZV5
Mode: Emergency
Initializing flash...OK
SW version: LS991ZVB_02
Android version: 6.0
LAF Version: 1.1
Product ID: PT03S150518006747
IMEI: 350305*******
Hardware: rev_10
Performed by 2.4.9.1 Software version.
Checking data...OK
Reading info...
Model ID: LGLS991
IMEI: 357355-******
Battery level: 39%
Mode: Emergency
LAF Version: 1.1
IMEI: 350305******
Target operator: SPR
Hardware: rev_10
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Opening "ls991zv9_12_arb02.oct"...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Writing PrimaryGPT...OK
Writing modem...OK
Writing pmic...OK
Writing sbl1...OK
Writing tz...OK
Writing sdi...OK
Writing hyp...OK
Writing rpm...OK
Writing aboot...OK
Writing sbl1bak...OK
Writing pmicbak...OK
Writing tzbak...OK
Writing hypbak...OK
Writing rpmbak...OK
Writing abootbak...OK
Writing sdibak...OK
Writing persist...OK
Writing sec...OK
Writing laf...OK
Writing boot...OK
Writing recovery...OK
Writing raw_resources...OK
Writing raw_resourcesbak...OK
Writing factory...OK
Writing system...OK
Writing userdata...OK
Writing BackupGPT...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
