Member: 64823
Thanks Meter: 439 | Is MEDUSA BOX ok? Even GOOD phone CANT connect ! I have a Dead BOOT i8190. Always FLASH UNKNOWN. Even i try to connect a WORKING phone still same PROBLEM i solder cable DIRECTLY. Good TP..
Is there a POSIBILITY that the BOX is damage? What can be BAD? Quote:
Log started at 2/28/2015 9:49:58 AM ...
Welcome to Medusa Box Software version 2.4.3
To make Repair Samsung GT-I8190 You need:
1. Connect it via Jtag cable to Box.
2. Connect to PC via USB cable (use both connection).
3. Install U8500 driver (if driver was not installed automatically) from folder "C:\Program Files\GSMServer\Medusa\Driver\U8500\" and try to connect the phone again.
Note: This phone can connect more longer, so You need to wait 30-50 seconds.
Operating Mode: EasyRepair Mode
Selected device model: Samsung GT-I8190
Connecting. Please wait...
Checking data...
Resetting target. Please wait...
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision C.
Detected TAP ID: 62286041, IR Length = 6.
MI: Found ST-Ericsson JTAG Router 62286041.
MI: Enabling ARM Cortex A9 core.
MI: Halting target, attempt 1.
JTAG speed : 2400 KHz.
VREF level : 1.79 V
CPU : ST-Ericsson U8500
Core ID : 4BA00477
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0xFFFFFFFF, cycle 0.
MI: Received status 0x0000F00F, cycle 1.
MI: Received server capabilities 0x00000011.
MI: Detailed server caps: FLASH, WDOG
MI: Watchdog are preconfigured.
MI: Server init.
MI: Received flash ID 0x00000000.
ERROR[008]: Unknown flash device. Device No:ID = 0:00000000.
ERROR[035]: Target device has been powered off during connect.
Please connect the target device and power it on...
Checking data...
VREF level : 1.80 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.79 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz.
JTAG speed : 1000 KHz.
VREF level : 1.80 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.80 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.80 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.79 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.79 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.79 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.80 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Checking data...
VREF level : 1.79 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
Operating Mode: Advanced Mode
Checking data...
VREF level : 1.80 V
Core ID : 4BA00477
MI: Starting...
MI: Server init.
