Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4)
Connecting...
Device : Unknown eMMC AFE00A
Page size : 512 B
Block size : 512 B
Block count : 1966080
CID Info
CID : 150000414645303041056E8C34CC8B21
Manufacturer ID : 0X15
Device/BGA : Device (removable)
OEM/Application ID : 0X00
Product name : AFE00A
Product revision : 0.5
Product serial number : (hex) 6E8C34CC
Manufacturing date : 08/2008
CSD Info
CSD : 9026012A0F5903BFF6DBFFE99640409D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 1.5 ms
TRAN speed : 20 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.2 (for MMC v4.2)
Erase block size : 0 Kbytes
Boot1 size : 0 Kbytes
Boot2 size : 0 Kbytes
RPMB size : 0 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Max enhanced data size: 0 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
EXT_CSD data error!!!
Connect unsuccessful!!!
