08-13-2020, 07:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | mi play lotus mtk dead with ufi but flashed with medusa phone alive Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC hC8aP Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68433861503E034841560E16C3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC8aP Product revision : 0.3 Product serial number : (hex) 4841560E Manufacturing date : 01/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/hC8aP_12_08_2020_20_19_27.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.2; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: expdb (00010C40, 0000A000) 20 MB P05: frp (0001AC40, 00000800) 1024 KB P06: nvcfg (0001B440, 00010000) 32 MB P07: nvdata (0002B440, 00020000) 64 MB P08: metadata (0004B440, 00010000) 32 MB P09: protect1 (0005B440, 00004000) 8 MB P10: protect2 (0005F440, 00004BC0) 9.469 MB P11: seccfg (00064000, 00004000) 8 MB P12: persist (00068000, 00018000) 48 MB P13: sec1 (00080000, 00001000) 2048 KB P14: proinfo (00081000, 00001800) 3072 KB P15: efuse (00082800, 00000400) 512 KB P16: md1img (00082C00, 00032000) 100 MB P17: spmfw (000B4C00, 00000800) 1024 KB P18: scp1 (000B5400, 00000800) 1024 KB P19: scp2 (000B5C00, 00000800) 1024 KB P20: sspm_1 (000B6400, 00000800) 1024 KB P21: sspm_2 (000B6C00, 00000800) 1024 KB P22: gz1 (000B7400, 00008000) 16 MB P23: gz2 (000BF400, 00008000) 16 MB P24: nvram (000C7400, 00020000) 64 MB P25: lk (000E7400, 00000800) 1024 KB P26: lk2 (000E7C00, 00000800) 1024 KB P27: boot (000E8400, 00010000) 32 MB P28: logo (000F8400, 00004000) 8 MB P29: odmdtbo (000FC400, 00008000) 16 MB P30: tee1 (00104400, 00002800) 5 MB P31: tee2 (00106C00, 00005400) 10.5 MB P32: vendor (0010C000, 00180000) 768 MB P33: cust (0028C000, 001A0000) 832 MB P34: system (0042C000, 00600000) 3072 MB P35: devinfo (00A2C000, 00004000) 8 MB P36: vbmeta (00A30000, 00004000) 8 MB P37: cache (00A34000, 000D8000) 432 MB P38: userdata (00B0C000, 069527DF) 52.66 GB P39: otp (0745E7DF, 00015800) 43 MB P40: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files/Medusa Pro Software/Backups/hC8aP_nvdata_0x2b440_0x20000_12_08_2020_20_19_27.b in file... Reading. Please wait... Done. Elapsed time 00:00:26 SW: 2.1.2; FW: 1.24. |
The Following User Says Thank You to pakmobiles For This Useful Post: |
