04-17-2021, 08:53 | #2 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Quote:
& if your eMMC is BGA221 then you need to connect BGA221 side in Box from Adapter. (sometimes need adjust Volt & Bus Speed) [NOTE: Some ICFriend/MOORC Adapter have Bug with Medusa Box] Last edited by Pijush Das; 04-17-2021 at 08:59. | |
The Following User Says Thank You to Pijush Das For This Useful Post: |
04-18-2021, 07:44 | #7 (permalink) | |
Freak Poster Join Date: Nov 2004 Age: 50
Member: 90058 Status: Offline Thanks Meter: 97 | Quote:
what's the real reason of my box not deducting emmc /emcp please gsmserver team help | |
04-19-2021, 10:23 | #8 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. This is a BGA221 case - you need to insert it into the socket with the correct side and connect the socket to the box with the correct side. Please check the connection of the flash drive by ISP according to the screenshot1 and screenshot2. |
04-19-2021, 16:42 | #9 (permalink) | |
the log Welcome to Medusa Pro Software version 2.2.0. Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 4 bits Bus speed : 20 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 10 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 10 MHz Connecting... ERROR[001]: Can not connect. No target device present. please help me | |
04-21-2021, 15:03 | #12 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We are working with kmqn10006b-b318 (Already tested). Also, this eMMC is in the support for writing FW. Unfortunately, your eMMC kmqn10006b-b318 is dead or you connected it incorrectly. This is a hardware problem on your end. |
04-22-2021, 05:43 | #13 (permalink) | |
