Need Pinout isp for samsung SM-J500h thanks before I have a phone samsung j500h, no emmc pinouts I can make a dump for recovery |
Hi. Please also make photo of phone's PCB in high quality, upload it somewhere and send us link to PM. |
Welcome to Medusa Pro Software version 1.2.3. Started. Reader #0: Generic Usb Smart Card Reader 0 Reader #1: Generic Usb Smart Card Reader 1 Please disconnect battery and USB cable. eMMC interface selected. Connecting... ERROR[001]: Can not connect. No target device present. He does not want to be connected. all connected File Holder checked many times I noticed the box does not always see the flash may somewhere have to solder or change something or apparently a problem in boxing and software |
Possible reasons why the device don't connect: 1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible. |
