11-01-2016, 12:11 | #1 (permalink) |
Insane Poster Join Date: Sep 2012 Location: belarus
Member: 1806875 Status: Offline Thanks Meter: 40 | Need Pinout isp for samsung SM-J500h thanks before I can make a dump for recovery |
The Following User Says Thank You to mirazg For This Useful Post: |
11-01-2016, 13:36 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Please also make photo of phone's PCB in high quality, upload it somewhere and send us link to PM. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
11-01-2016, 15:22 | #4 (permalink) |
Member: 1806875 Status: Offline Thanks Meter: 40 | Welcome to Medusa Pro Software version 1.2.3. Started. Reader #0: Generic Usb Smart Card Reader 0 Reader #1: Generic Usb Smart Card Reader 1 Please disconnect battery and USB cable. eMMC interface selected. Connecting... ERROR[001]: Can not connect. No target device present. He does not want to be connected. all connected File Holder checked many times I noticed the box does not always see the flash may somewhere have to solder or change something or apparently a problem in boxing and software Last edited by Medusa Box; 11-02-2016 at 11:02. |
11-02-2016, 12:48 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Possible reasons why the device don't connect: 1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible. |
