11-30-2019, 08:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Not Reachable Age: 31
Member: 1351351 Status: Offline Thanks Meter: 277 | oppo F11pro cph1969 locks done medusapro Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC hDEaP3 Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 90014A6844456150330321C1542F66DB Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hDEaP3 Product revision : 0.3 Product serial number : (hex) 21C1542F Manufacturing date : 06/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40714240 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 1f000000 bytes Device sector size : 512 bytes Partition offset : 4308992 Number of sectors : 10911744 Build ID :PPR1.180610.011 Release ID :9 Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :full_oppo6771_18531-user 9 PPR1.180610.011 eng.root.20191108.032104 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_30_11_2019_13_11_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00020000) 64 MB P03: para (00020840, 00000400) 512 KB P04: opporeserve1 (00020C40, 00004000) 8 MB P05: opporeserve2 (00024C40, 00020000) 64 MB P06: opporeserve3 (00044C40, 00020000) 64 MB P07: oppo_custom (00064C40, 00000800) 1024 KB P08: expdb (00065440, 0000A000) 20 MB P09: frp (0006F440, 00000800) 1024 KB P10: nvcfg (0006FC40, 00010000) 32 MB P11: nvdata (0007FC40, 00020000) 64 MB P12: metadata (0009FC40, 00010000) 32 MB P13: protect1 (000AFC40, 00004000) 8 MB P14: protect2 (000B3C40, 000043C0) 8.469 MB P15: seccfg (000B8000, 00004000) 8 MB P16: persist (000BC000, 00018000) 48 MB P17: sec1 (000D4000, 00001000) 2048 KB P18: proinfo (000D5000, 00001800) 3072 KB P19: md1img (000D6800, 00032000) 100 MB P20: spmfw (00108800, 00000800) 1024 KB P21: scp1 (00109000, 00003000) 6 MB P22: scp2 (0010C000, 00003000) 6 MB P23: sspm_1 (0010F000, 00000800) 1024 KB P24: sspm_2 (0010F800, 00000800) 1024 KB P25: cam_vpu1 (00110000, 00007800) 15 MB P26: cam_vpu2 (00117800, 00007800) 15 MB P27: cam_vpu3 (0011F000, 00007800) 15 MB P28: gz1 (00126800, 00008000) 16 MB P29: gz2 (0012E800, 00008000) 16 MB P30: nvram (00136800, 00020000) 64 MB P31: lk (00156800, 00002800) 5 MB P32: lk2 (00159000, 00002800) 5 MB P33: boot (0015B800, 00010000) 32 MB P34: logo (0016B800, 00008000) 16 MB P35: dtbo (00173800, 00008000) 16 MB P36: tee1 (0017B800, 00002800) 5 MB P37: tee2 (0017E000, 00006000) 12 MB P38: odm (00184000, 00080000) 256 MB P39: vendor (00204000, 00218000) 1072 MB P40: system (0041C000, 00A68000) 5.203 GB P41: cache (00E84000, 000D8000) 432 MB P42: userdata (00F5C000, 0D97E7DF) 108.7 GB P43: otp (0E8DA7DF, 00015800) 43 MB P44: flashinfo (0E8EFFDF, 00008000) 16 MB after erase userdata and frp partition done........ |
The Following User Says Thank You to suriyas1 For This Useful Post: |
11-30-2019, 11:12 | #3 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | weldone good Work Canu Share The Files Too,,, |
The Following User Says Thank You to asia_gsm For This Useful Post: |
