07-13-2020, 18:07 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1867244 Status: Offline Thanks Meter: 63 | problem repairing G925FD UFS [Answered] i tried to repair UFS chip of a G925fd using SRf but i got these errors can u help me where the problem is ?? thanks Write descriptor succes Write descriptor compare succes Disconnected. Selected UFS BGA095 socket. Connected. Reading information. Manufacturer name: SAMSUNG Product name: KLUBG4G1BD-E0B1 Serial Number: 7DF18A9082080182 OEM ID: SAMSUNG_OEM_ID Page size : 4096 B Block size : 4096 B Block count : 7814144 Size : 29.81 GB (30524.00 MB) AttrRefClkFreeq = 1 MaxDataInSize = 4096 MaxDataOutSize = 4096 Connect successful. --------------------------------------------------------------- Physical partition number: 0 Block count : 7810048 (0x772C00) Size : 29.79 GB (30508.00 MB) Physical partition number: 1 Block count : 1024 (0x400) Size : 4.00 MB Physical partition number: 2 Block count : 1024 (0x400) Size : 4.00 MB ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: Authentication Key not yet programmed. Writing OEM ID String Descriptor successfully finished. Disconnected. Selected UFS BGA095 socket. Connected. Reading information. Manufacturer name: SAMSUNG Product name: KLUBG4G1BD-E0B1 Serial Number: 7DF18A9082080182 OEM ID: SAMSUNG_OEM_ID Page size : 4096 B Block size : 4096 B Block count : 7814144 Size : 29.81 GB (30524.00 MB) AttrRefClkFreeq = 1 MaxDataInSize = 4096 MaxDataOutSize = 4096 Connect successful. --------------------------------------------------------------- Physical partition number: 0 Block count : 7810048 (0x772C00) Size : 29.79 GB (30508.00 MB) Physical partition number: 1 Block count : 1024 (0x400) Size : 4.00 MB Physical partition number: 2 Block count : 1024 (0x400) Size : 4.00 MB ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: Authentication Key not yet programmed. Write descriptor succes Write descriptor compare error!!! Write descriptor succes Write descriptor compare error!!! Write descriptor succes Write descriptor compare error!!! Write descriptor succes Write descriptor compare error!!! |
07-14-2020, 08:24 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Why You have decided to write descriptors? The descriptors should be written in WM G1! |
The Following User Says Thank You to Medusa Box For This Useful Post: |
07-14-2020, 11:21 | #3 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | as i know there is no srf or repair files for G925FD what was upload for G925F |
The Following 3 Users Say Thank You to starkrimes For This Useful Post: |
07-15-2020, 08:03 | #5 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
