04-28-2020, 01:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | Redmi 7 isp connection done! Code: Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 1 bit Bus speed : 8 MHz Connecting... Device : Samsung eMMC GP6BMB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100475036424D4201FC3D9BD62681 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GP6BMB Product revision : 0.1 Product serial number : (hex) FC3D9BD6 Manufacturing date : 02/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 6422528 Number of sectors : 7340032 Device Manufacturer : xiaomi Build ID : PKQ1.181021.001 Display Build ID : PKQ1.181021.001 Release ID : 9 Device Model : Redmi 7 Device Name : onc Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : onc-user 9 PKQ1.181021.001 V11.0.2.0.PFLMIXM release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GP6BMB_26_04_2020_09_24_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: switch (00000058, 00000020) 16 KB P05: sec (00000078, 00000048) 36 KB P06: DDR (000000C0, 00000080) 64 KB P07: config (00000140, 00000080) 64 KB P08: limits (000001C0, 00000040) 32 KB P09: lksecapp (00000200, 00000100) 128 KB P10: lksecappbak (00000300, 00000100) 128 KB P11: devcfg (00000400, 00000200) 256 KB P12: devcfgbak (00000600, 00000200) 256 KB P13: apdp (00000800, 00000200) 256 KB P14: msadp (00000A00, 00000200) 256 KB P15: rpm (00000C00, 00000400) 512 KB P16: rpmbak (00001000, 00000400) 512 KB P17: mota (00001400, 00000400) 512 KB P18: keystore (00001800, 00000400) 512 KB P19: syscfg (00001C00, 00000400) 512 KB P20: misc (00002000, 00000800) 1024 KB P21: dip (00002800, 00000800) 1024 KB P22: sbl1 (00003000, 00000800) 1024 KB P23: sbl1bak (00003800, 00000800) 1024 KB P24: cmnlib (00004000, 00000800) 1024 KB P25: cmnlibbak (00004800, 00000800) 1024 KB P26: cmnlib64 (00005000, 00000800) 1024 KB P27: cmnlib64bak (00005800, 00000800) 1024 KB P28: keymaster (00006000, 00000800) 1024 KB P29: keymasterbak (00006800, 00000800) 1024 KB P30: aboot (00007000, 00001000) 2048 KB P31: abootbak (00008000, 00001000) 2048 KB P32: fsg (00009000, 00001000) 2048 KB P33: tz (0000A000, 00002000) 4 MB P34: tzbak (0000C000, 00002000) 4 MB P35: mcfg (0000E000, 00002000) 4 MB P36: modemst1 (00010000, 00004000) 8 MB P37: modemst2 (00014000, 00004000) 8 MB P38: devinfo (00018000, 00004000) 8 MB P39: devbk1 (0001C000, 00004000) 8 MB P40: dsp (00020000, 00008000) 16 MB P41: oops (00028000, 00008000) 16 MB P42: splash (00030000, 00010000) 32 MB P43: persist (00040000, 00020000) 64 MB P44: persistbak (00060000, 00020000) 64 MB P45: mdtp (00080000, 00010000) 32 MB P46: logdump (00090000, 00030000) 96 MB P47: boot (000C0000, 00020000) 64 MB P48: recovery (000E0000, 00020000) 64 MB P49: modem (00100000, 0002C000) 88 MB P50: logo (0012C000, 0000F800) 31 MB P51: dtbo (0013B800, 00004000) 8 MB P52: vbmeta (0013F800, 00000800) 1024 KB P53: miuidump (00140000, 00040000) 128 MB P54: cache (00180000, 00080000) 256 MB P55: oem (00200000, 00080000) 256 MB P56: cust (00280000, 001A0000) 832 MB P57: vendor (00420000, 00200000) 1024 MB P58: system (00620000, 00700000) 3584 MB P59: userdata (00D20000, 0675BFDF) 51.68 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GP6BMB_fsg_0x9000_0x1000_26_04_2020_09_24_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.0.9; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GP6BMB_modemst1_0x10000_0x4000_26_04_2020_09_24_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.0.9; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GP6BMB_modemst2_0x14000_0x4000_26_04_2020_09_24_58.bin file... Reading. Please wait... Done. Elapsed time 00:01:46 SW: 2.0.9; FW: 1.24. |
The Following 3 Users Say Thank You to mcdiniz For This Useful Post: |
