02-16-2015, 08:31 | #1 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: CABA, Argentina
Member: 1607814 Status: Offline Sonork: 100.1658107 Thanks Meter: 10 | Repair Boot Samsung Ace S5830L Done SAMSUNG_GTS5830_Repair.mf Repair and Full Dump Samsung_GTS5830_FullFlash.rar Unzip the folder Firmware Medusa C:\Program Files\GsmServer\Medusa\Firmware Open Medusa / Octoplus Jtag Select Samsung S5830 Solder JTAG cable Insert Battery and USB Cable Now'll select "AdvancedRepair Mode" Send to Connect, Select Boot Only Give and Erase / Erase Wait ends Then FullFlash and give Erase / Erase Wait for it to finish Sign Out Repair in "EasyRepair Mode" Select the File SAMSUNG_GTS5830_Repair.mf Write the Imxx and repair Quote:
Send to Connect, Select Full Flash Select the FullDump Downloaded and decompressed in the Folder Firmware and expect Finish This process will take, is preferable to leave the pc alone until the process ends After the end of the process, the team will ignite still a S5830, check the Imxx * # 06 # if you have the generic IMXX, just what you repair with a Box, or the Same, reconnecting all, select "EasyRepair Mode" and reparation boot, placing the original Imxx, wait for it to finish, and turns without FullFlash again, and began to Imxx written. NOTE: The process I've done in a 1Mhz speed, if you get errors RTCK or Auto Select to 1Mhz. Last edited by Octopus box; 02-16-2015 at 08:58. | |
