01-07-2021, 16:47 | #1 (permalink) |
Junior Member Join Date: Sep 2020 Location: turkey Age: 39
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | Samsung a730 emmc problem [Answered] Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) |
01-08-2021, 09:28 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
Please, try to set another Voltage and Bus speed, then try to establish connection again | |
01-08-2021, 19:56 | #3 (permalink) |
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... Device : Samsung eMMC CKTM4R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100434B544D345200D6CCB87E6557 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CKTM4R Product revision : 0.0 Product serial number : (hex) D6CCB87E Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CKTM4R_08_01_2021_10_41_45.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: NA (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: CM (00014000, 00004000) 8 MB P06: m9kefs1 (00018000, 00002000) 4 MB P07: m9kefs2 (0001A000, 00002000) 4 MB P08: m9kefs3 (0001C000, 00002000) 4 MB P09: NAD_REFER (0001E000, 00000800) 1024 KB P10: PARAM (0001E800, 00004000) 8 MB P11: MISC (00022800, 00001000) 2048 KB P12: BOOT (00023800, 00010000) 32 MB P13: RECOVERY (00033800, 00013000) 38 MB P14: BOTA1 (00046800, 00004000) 8 MB P15: RADIO (0004A800, 00016800) 45 MB P16: PERSISTENT (00061000, 00000400) 512 KB P17: STEADY (00061400, 00002000) 4 MB P18: RESERVED2 (00063400, 00000C00) 1536 KB P19: SYSTEM (00064000, 007C0000) 3968 MB P20: CACHE (00824000, 0007D000) 250 MB P21: HIDDEN (008A1000, 00002800) 5 MB P22: OMR (008A3800, 00019000) 50 MB P23: CP_DEBUG (008BC800, 00002800) 5 MB P24: NAD_FW (008BF000, 0000A000) 20 MB P25: USERDATA (008C9000, 06BB0000) 53.84 GB Backuping EFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_EFS_0x6000_0xa000_08_01_2021_10_41_45.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.8; FW: 2.00. Backuping CPEFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_CPEFS_0x10000_0x4000_08_01_2021_10_41_45.bi n file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.8; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 409600 Number of sectors : 8126464 Device Manufacturer : samsung Build ID : PPR1.180610.011 Display Build ID : PPR1.180610.011.A730FXXU7CTE1 Release ID : 9 Device Model : SM-A730F Device Name : jackpot2ltexx Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : jackpot2ltexx-user 9 PPR1.180610.011 A730FXXU7CTE1 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 74. Get Measurements error. Reloading... Disconnected. Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... Device : Samsung eMMC CKTM4R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100434B544D345200D6CCB87E6557 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CKTM4R Product revision : 0.0 Product serial number : (hex) D6CCB87E Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CKTM4R_08_01_2021_10_51_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: NA (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: CM (00014000, 00004000) 8 MB P06: m9kefs1 (00018000, 00002000) 4 MB P07: m9kefs2 (0001A000, 00002000) 4 MB P08: m9kefs3 (0001C000, 00002000) 4 MB P09: NAD_REFER (0001E000, 00000800) 1024 KB P10: PARAM (0001E800, 00004000) 8 MB P11: MISC (00022800, 00001000) 2048 KB P12: BOOT (00023800, 00010000) 32 MB P13: RECOVERY (00033800, 00013000) 38 MB P14: BOTA1 (00046800, 00004000) 8 MB P15: RADIO (0004A800, 00016800) 45 MB P16: PERSISTENT (00061000, 00000400) 512 KB P17: STEADY (00061400, 00002000) 4 MB P18: RESERVED2 (00063400, 00000C00) 1536 KB P19: SYSTEM (00064000, 007C0000) 3968 MB P20: CACHE (00824000, 0007D000) 250 MB P21: HIDDEN (008A1000, 00002800) 5 MB P22: OMR (008A3800, 00019000) 50 MB P23: CP_DEBUG (008BC800, 00002800) 5 MB P24: NAD_FW (008BF000, 0000A000) 20 MB P25: USERDATA (008C9000, 06BB0000) 53.84 GB Backuping EFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_EFS_0x6000_0xa000_08_01_2021_10_51_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.8; FW: 2.00. Backuping CPEFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_CPEFS_0x10000_0x4000_08_01_2021_10_51_58.bi n file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.8; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 409600 Number of sectors : 8126464 Device Manufacturer : samsung Build ID : PPR1.180610.011 Display Build ID : PPR1.180610.011.A730FXXU7CTE1 Release ID : 9 Device Model : SM-A730F Device Name : jackpot2ltexx Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : jackpot2ltexx-user 9 PPR1.180610.011 A730FXXU7CTE1 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 74. Remove write protect successfully completed. Disconnected. |
01-08-2021, 20:31 | #4 (permalink) |
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: Generic EMV Smartcard Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC CKTM4R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100434B544D345200D6CCB87E6557 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CKTM4R Product revision : 0.0 Product serial number : (hex) D6CCB87E Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CKTM4R_08_01_2021_11_20_03.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: NA (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: CM (00014000, 00004000) 8 MB P06: m9kefs1 (00018000, 00002000) 4 MB P07: m9kefs2 (0001A000, 00002000) 4 MB P08: m9kefs3 (0001C000, 00002000) 4 MB P09: NAD_REFER (0001E000, 00000800) 1024 KB P10: PARAM (0001E800, 00004000) 8 MB P11: MISC (00022800, 00001000) 2048 KB P12: BOOT (00023800, 00010000) 32 MB P13: RECOVERY (00033800, 00013000) 38 MB P14: BOTA1 (00046800, 00004000) 8 MB P15: RADIO (0004A800, 00016800) 45 MB P16: PERSISTENT (00061000, 00000400) 512 KB P17: STEADY (00061400, 00002000) 4 MB P18: RESERVED2 (00063400, 00000C00) 1536 KB P19: SYSTEM (00064000, 007C0000) 3968 MB P20: CACHE (00824000, 0007D000) 250 MB P21: HIDDEN (008A1000, 00002800) 5 MB P22: OMR (008A3800, 00019000) 50 MB P23: CP_DEBUG (008BC800, 00002800) 5 MB P24: NAD_FW (008BF000, 0000A000) 20 MB P25: USERDATA (008C9000, 06BB0000) 53.84 GB Backuping EFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_EFS_0x6000_0xa000_08_01_2021_11_20_03.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.8; FW: 2.00. Backuping CPEFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_CPEFS_0x10000_0x4000_08_01_2021_11_20_03.bi n file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.8; FW: 2.00. RPMB: Counter of the successful data write requests = 74. Disconnected. Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... Device : Samsung eMMC CKTM4R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100434B544D345200D6CCB87E6557 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CKTM4R Product revision : 0.0 Product serial number : (hex) D6CCB87E Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CKTM4R_08_01_2021_11_20_55.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: NA (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: CM (00014000, 00004000) 8 MB P06: m9kefs1 (00018000, 00002000) 4 MB P07: m9kefs2 (0001A000, 00002000) 4 MB P08: m9kefs3 (0001C000, 00002000) 4 MB P09: NAD_REFER (0001E000, 00000800) 1024 KB P10: PARAM (0001E800, 00004000) 8 MB P11: MISC (00022800, 00001000) 2048 KB P12: BOOT (00023800, 00010000) 32 MB P13: RECOVERY (00033800, 00013000) 38 MB P14: BOTA1 (00046800, 00004000) 8 MB P15: RADIO (0004A800, 00016800) 45 MB P16: PERSISTENT (00061000, 00000400) 512 KB P17: STEADY (00061400, 00002000) 4 MB P18: RESERVED2 (00063400, 00000C00) 1536 KB P19: SYSTEM (00064000, 007C0000) 3968 MB P20: CACHE (00824000, 0007D000) 250 MB P21: HIDDEN (008A1000, 00002800) 5 MB P22: OMR (008A3800, 00019000) 50 MB P23: CP_DEBUG (008BC800, 00002800) 5 MB P24: NAD_FW (008BF000, 0000A000) 20 MB P25: USERDATA (008C9000, 06BB0000) 53.84 GB Backuping EFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_EFS_0x6000_0xa000_08_01_2021_11_20_55.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.8; FW: 2.00. Backuping CPEFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_CPEFS_0x10000_0x4000_08_01_2021_11_20_55.bi n file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.8; FW: 2.00. RPMB: Counter of the successful data write requests = 74. Selected pit file: C:/Program Files (x86)/Medusa Pro Software/A730F/BOOT_08_01_2021_09_39_34.bin Unknown format of input file C:/Program Files (x86)/Medusa Pro Software/A730F/BOOT_08_01_2021_09_39_34.bin! Selected pit file: C:/Users/-ADAL-/Desktop/A730FXXU7CTE1-(ILO) (Firmware 4 Files) (Android 9 Pie)/A730FXXU7CTE1-(ILO) (Firmware 4 Files) (Android 9 Pie) File By (Support.**************)/CSC_OJM_A730FOJM7CTE3_CL18659853_QB31584394_REV00_ user_low_ship.tar/JACKPOT2LTE_EUR_OPEN.pit Selected pit file: C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/CSC_UWB_A730FUWB4BSB1_CL14354400_QB21945741_REV00_ user_low_ship.tar/JACKPOT2LTE_EUR_OPEN_HIDDEN100M.pit Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/CSC_UWB_A730FUWB4BSB1_CL14354400_QB21945741_REV00_ user_low_ship.tar.md5". Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/CP_A730FXXS4BSB1_CP11823575_CL14344870_QB21845348_ REV00_user_low_ship.tar.md5". Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/BL_A730FXXS4BSB1_CL14344870_QB21845348_REV00_user_ low_ship.tar.md5". Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/AP_A730FXXS4BSB1_CL14344870_QB21845348_REV00_user_ low_ship_meta.tar.md5". Writing MBR... ERROR[012]: Write error. At sector 0. Disconnected. Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... ERROR[001]: Can not connect. No target device present. Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... ERROR[001]: Can not connect. No target device present. Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.0V Bus Mode : 1 bit Bus speed : 25 MHz Full speed mode! Connecting... ERROR[001]: Can not connect. No target device present. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.0V Bus Mode : 1 bit Bus speed : 25 MHz Full speed mode! Connecting... ERROR[001]: Can not connect. No target device present. Get Measurements error. Reloading... Model Settings: Interface : USB Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.0V Bus Mode : 1 bit Bus speed : 25 MHz Full speed mode! Connecting... Device : Samsung eMMC CKTM4R Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100434B544D345200D6CCB87E6557 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CKTM4R Product revision : 0.0 Product serial number : (hex) D6CCB87E Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CKTM4R_08_01_2021_11_28_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: NA (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: CM (00014000, 00004000) 8 MB P06: m9kefs1 (00018000, 00002000) 4 MB P07: m9kefs2 (0001A000, 00002000) 4 MB P08: m9kefs3 (0001C000, 00002000) 4 MB P09: NAD_REFER (0001E000, 00000800) 1024 KB P10: PARAM (0001E800, 00004000) 8 MB P11: MISC (00022800, 00001000) 2048 KB P12: BOOT (00023800, 00010000) 32 MB P13: RECOVERY (00033800, 00013000) 38 MB P14: BOTA1 (00046800, 00004000) 8 MB P15: RADIO (0004A800, 00016800) 45 MB P16: PERSISTENT (00061000, 00000400) 512 KB P17: STEADY (00061400, 00002000) 4 MB P18: RESERVED2 (00063400, 00000C00) 1536 KB P19: SYSTEM (00064000, 007C0000) 3968 MB P20: CACHE (00824000, 0007D000) 250 MB P21: HIDDEN (008A1000, 00002800) 5 MB P22: OMR (008A3800, 00019000) 50 MB P23: CP_DEBUG (008BC800, 00002800) 5 MB P24: NAD_FW (008BF000, 0000A000) 20 MB P25: USERDATA (008C9000, 06BB0000) 53.84 GB Backuping EFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_EFS_0x6000_0xa000_08_01_2021_11_28_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.8; FW: 2.00. Backuping CPEFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CKTM4R_CPEFS_0x10000_0x4000_08_01_2021_11_28_00.bi n file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.8; FW: 2.00. RPMB: Counter of the successful data write requests = 74. Selected pit file: C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/A730FXXS4BSB1_8.0.exe Unknown format of input file C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/A730FXXS4BSB1_8.0.exe! Selected pit file: C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/A730FXXS4BSB1_8.0.exe Unknown format of input file C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/A730FXXS4BSB1_8.0.exe! Selected pit file: C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/CSC_UWB_A730FUWB4BSB1_CL14354400_QB21945741_REV00_ user_low_ship.tar/JACKPOT2LTE_EUR_OPEN_HIDDEN100M.pit Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/BL_A730FXXS4BSB1_CL14344870_QB21845348_REV00_user_ low_ship.tar.md5". Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/AP_A730FXXS4BSB1_CL14344870_QB21845348_REV00_user_ low_ship_meta.tar.md5". Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/CP_A730FXXS4BSB1_CP11823575_CL14344870_QB21845348_ REV00_user_low_ship.tar.md5". Open file "C:/Users/-ADAL-/Desktop/A730FXXS4BSB1_8.0/CSC_UWB_A730FUWB4BSB1_CL14354400_QB21945741_REV00_ user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT... ERROR[012]: Write error. At sector 0. Disconnected |
01-09-2021, 12:07 | #5 (permalink) |
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | RPMB: Counter of the successful data write requests = 74. Erasing partition USERDATA... Done. Erasing is finished. SW: 2.1.8; FW: 2.00. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.1.8; FW: 2.00. Disconnected. |
