05-13-2020, 05:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | Samsung sm-a720 frp reset via isp & solution connection handle AS WRITTEN ON THE TITLE OF THREAD GOT SAMSUNG SM-A720 WITH FRP AND USB HOSTs DP-DM LINES DAMAGED UNDER CPU AND HERE MY RESULTE NOTICE : SRF FILES WAS MADE BEFORE FROM WORKING DEVICE VIA ADB BY ROOTED DEVICE AND I HAD LUCKY TO TRY IT ON THAT NEW PHONE FOR HANDLE CONNECTION ON THAT DEVICE I USED 2 RESISTORS VALUE : 150OHM LOG INFO : Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 2 Reader #3: Alcor Micro USB Smart Card Reader 3 Loading firmware. Please wait... Done. Selected eMMC interface. Selected PIN - CONNECTOR socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC BJNB4R Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100424A4E42345210249AFA919483 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : BJNB4R Product revision : 1.0 Product serial number : (hex) 249AFA91 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 9928704 Device Manufacturer : samsung Device Platform : exynos5 Build ID : R16NW Display Build ID : R16NW.A720FXXU8CSF1 Release ID : 8.0.0 Device Model : SM-A720F Device Name : a7y17ltexx Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a7y17ltexx-user 8.0.0 R16NW A720FXXU8CSF1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/BJNB4R_13_05_2020_05_18_42.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: RADIO (00045800, 00016800) 45 MB P14: TOMBSTONES (0005C000, 00000800) 1024 KB P15: DNT (0005C800, 00000800) 1024 KB P16: PERSISTENT (0005D000, 00000400) 512 KB P17: STEADY (0005D400, 00000800) 1024 KB P18: RESERVED2 (0005DC00, 00002400) 4.5 MB P19: SYSTEM (00060000, 00978000) 4.734 GB P20: CACHE (009D8000, 00064000) 200 MB P21: HIDDEN (00A3C000, 00064000) 200 MB P22: CP_DEBUG (00AA0000, 00002800) 5 MB P23: NAD_FW (00AA2800, 0000A000) 20 MB P24: NAD_REFER (00AAC800, 00000800) 1024 KB P25: USERDATA (00AAD000, 02F8E000) 23.78 GB Backuping EFS partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/BJNB4R_EFS_0x6000_0xa000_13_05_2020_05_18_42.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.0.9; FW: 2.00. RPMB: Counter of the successful data write requests = 2. LOG FRP REMOVING : Code: Repairing from file "C:/Users/STARKRIMES/Desktop/A720F/Samsung_SM-A720F_eMMC_by_STARKRIMES.srf". Write data verification is enabled. Writing PERSISTENT partition... Done. Smart Repair is successfully complete. SW: 2.0.9; FW: 2.00. Disconnected. Download MEDUSA PRO II Software Find out more at: https://medusabox.com/ |
The Following 4 Users Say Thank You to starkrimes For This Useful Post: |
