07-13-2017, 23:41 | #1 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1629966 Status: Offline Thanks Meter: 3 | SE U20a question i do this: first i connect the JTAG to phone then i connect the USB cable and the battery then in the program i click start and continue until appears the window and i press power in the phone, but always the same errors Please help me Thank you |
07-14-2017, 06:07 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. The problem can be with powering the device. Try to do the next: 1. Reboot PC. 2. Carefully check soldering of each JTAG wire again, solder them as short as possible (max. 3-5 CM length). 3. To power the device please use BOTH - fully charged battery (or external power supply) AND USB cable. 4. Also try to connect the device with different JTAG speed values. Try to connect a few times. 5. Post the result. Also, please look here: http://forum.gsmhosting.com/vbb/f664...ml#post9295990, http://forum.gsmhosting.com/vbb/f664...ml#post8301854, http://forum.gsmhosting.com/vbb/f664...7/#post8301567. and here: https://www.youtube.com/watch?v=U8Jf...fkGOeItKjPJMGK, https://www.youtube.com/watch?v=QU7OYhmE8lM, https://www.youtube.com/watch?v=YVwwvjZ7gD8. Last edited by Medusa Box; 07-14-2017 at 06:13. |
