09-13-2016, 09:09 | #1 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Sm-g318mz need pit file or bootfile Quote:
09-13-2016, 10:04 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. What is the state of your device exactly? As You can see: Quote:
09-13-2016, 10:29 | #3 (permalink) | |
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Quote:
09-13-2016, 10:36 | #4 (permalink) |
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Switch succes!!! Opening C:/Program Files/Medusa Pro Software/boot 1/Hynix eMMC H4G2b_13_09_2016_17_34_18.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 1.1.9; FW: 1.11. |
09-13-2016, 11:40 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to find the same phone model Sm-g318mz (or Sm-g318xx), create Repair file from it and use it for repairing your device. Or try to find PIT file and make Factory Repair. Maybe someone have and will upload it here for You. |
09-13-2016, 14:17 | #10 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | Hi Bro! SM-G318MZ PIT file LINK You need BL Boot file? BL_G318MZDXU0APB1_CL963916_QB8432380_REV03_user_lo w_ship.tar.md5 LINK Best Regards ddilshod93 Last edited by ddilshod93; 09-13-2016 at 14:27. |
The Following User Says Thank You to ddilshod93 For This Useful Post: |
09-14-2016, 06:43 | #12 (permalink) |
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Selected pit file: D:/SAMSUNG/SAM ODIN/G318MZ/SM-G318MZ_VIVALTO_ML_4GB_20150210.pit Selected firmware file: D:/SAMSUNG/SAM ODIN/G318MZ/BL_G318MZDXU0APB1_CL963916_QB8432380_REV03_user_lo w_ship.tar.md5 Writing MBR Writing primary GPT Writing secondary GPT Writing PIT Writting. Please wait... Writting partition BOOT... Done. Writting partition SBOOT... Done. Writting partition SBOOT2... Done. Writting partition PARAM... Done. Writting is finished. SW: 1.1.9; FW: 1.11. |
09-14-2016, 07:45 | #13 (permalink) |
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | STILL DEAD BOOT SIR Selected pit file: D:/SAMSUNG/SAM ODIN/G318MZ/SM-G318MZ_VIVALTO_ML_4GB_20150210.pit Selected firmware file: K:/2016 FIRMWARE STOCK/SAMSUNG/SAM/SM-G318MZ/G318MZDXU0AOG1_G318MZOLC0AOG1_G318MZDXU0AOG1_HOME. tar.md5 Writing MBR Writing primary GPT Writing secondary GPT Writing PIT Writting. Please wait... Writting partition wfixnv2... Done. Writting partition WDSP... Done. Writting partition MODEM... Done. Writting partition KERNEL... Done. Writting partition RECOVERY... Done. Writting partition CSC... Done. Writting partition system... Done. Writting partition HIDDEN... Done. Writting is finished. SW: 1.1.9; FW: 1.11. |
09-14-2016, 07:59 | #14 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | If after repairing the phone it still doesn't go into Download Mode - most likely, your phone's flash chip doesn't allow to make repair. Some flash chips don't allow to make repair/write data (eMMC flash chip has write data protection and it doesn't allow to write boot or some other partitions even write process was shown successfully completed). In this case, You need to solder new flash chip and then make Repair. Currently no another solution. The problem also can be with version of phone's boot loaders. Boot loaders in firmware file, which You have written, can be not suitable with your phone. Try to make Factory Repair using different firmwares. Also, boot in "Boot partition 1" can be damaged. Try to find the same phone model, read out "Boot partition 1" and write it into your phone, then make Factory Repair again. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
