01-06-2020, 08:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Student
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | CPH 1803 How to flash [Answered] Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC hB8aP> Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68423861503E032794B816A555 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hB8aP> Product revision : 0.3 Product serial number : (hex) 2794B816 Manufacturing date : 10/2018 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------File open failed: C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hB8aP>_06_01_2020_13_16_27.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.0; FW: 1.24. |
01-06-2020, 20:11 | #6 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | then u don't need to flash it just reconnect the emmc and try highlight the voltage from 2.2 to max 2.8v and bus speed set to auto if Searching Android build info = show phone info then you're correct if shows Not found try to highlight bus mode then just write the isp.srf if no try to contact with me and will try help you |
01-07-2020, 09:16 | #7 (permalink) | |
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | Quote:
sped chang not connect error chang BUS Spide & Buss Moad same error Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s_CPH1803 SRF : C:/Users/Mobile Care/Desktop/CPH1937_11_A.16/Oppo_A3s_CPH1803_RESET_ISP.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : 1 MHz Connecting... Device : Hynix eMMC hB8aP> Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68423861503E032794B816A555 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hB8aP> Product revision : 0.3 Product serial number : (hex) 2794B816 Manufacturing date : 10/2018 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 2064384 Number of sectors : 7030784 Build ID : OPM1.171019.026 Release ID : 8.1.0 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191128.013212 release-keys File open failed: C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hB8aP>_07_01_2020_13_59_59.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.1; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: reserve_exp1 (0003F828, 00001000) 2048 KB P09: reserve_exp2 (00040828, 00001000) 2048 KB P10: fsc (00041828, 00000002) 1024 b P11: ssd (00041830, 00000010) 8 KB P12: sbl1 (00041840, 00000400) 512 KB P13: rpm (00041C40, 00000400) 512 KB P14: tz (00042040, 00001000) 2048 KB P15: devcfg (00043040, 00000200) 256 KB P16: sbl1bak (00043240, 00000400) 512 KB P17: rpmbak (00043640, 00000400) 512 KB P18: tzbak (00043A40, 00001000) 2048 KB P19: devcfgbak (00044A40, 00000200) 256 KB P20: dsp (00044C40, 00008000) 16 MB P21: DDR (00050000, 00000040) 32 KB P22: fsg (00050040, 00000C00) 1536 KB P23: sec (00050C40, 00000020) 16 KB P24: aboot (00050C60, 00000800) 1024 KB P25: abootbak (00051460, 00000800) 1024 KB P26: modem (00051C60, 00040000) 128 MB P27: dtbo (00091C60, 00004000) 8 MB P28: vbmeta (00095C60, 00000080) 64 KB P29: boot (00095CE0, 00020000) 64 MB P30: recovery (000B5CE0, 00020000) 64 MB P31: devinfo (000D5CE0, 00000800) 1024 KB P32: splash (000D8000, 00005800) 11 MB P33: LOGO (000DD800, 00010000) 32 MB P34: DRIVER (000ED800, 00010000) 32 MB P35: cache (000FD800, 00080000) 256 MB P36: misc (0017D800, 00000800) 1024 KB P37: keystore (0017E000, 00000400) 512 KB P38: config (0017E400, 00000040) 32 KB P39: oem (0017E440, 00000800) 1024 KB P40: limits (00180000, 00000040) 32 KB P41: mota (00184000, 00000400) 512 KB P42: dip (00184400, 00000800) 1024 KB P43: mdtp (00184C00, 00010000) 32 MB P44: syscfg (00194C00, 00000400) 512 KB P45: mcfg (00195000, 00002000) 4 MB P46: lksecapp (00198000, 00000100) 128 KB P47: cmnlib (00198100, 00000800) 1024 KB P48: cmnlib64 (00198900, 00000800) 1024 KB P49: keymaster (00199100, 00000800) 1024 KB P50: lksecappbak (00199900, 00000100) 128 KB P51: cmnlibbak (00199A00, 00000800) 1024 KB P52: cmnlib64bak (0019A200, 00000800) 1024 KB P53: keymasterbak (0019AA00, 00000800) 1024 KB P54: apdp (0019C000, 00000200) 256 KB P55: msadp (0019C200, 00000200) 256 KB P56: dpo (0019C400, 00000010) 8 KB P57: logdump (0019C410, 00020000) 64 MB P58: vm-kystore (001BC410, 00000800) 1024 KB P59: vm-data (001BCC10, 00005000) 10 MB P60: hyp (001C4000, 00004000) 8 MB P61: vm-system (001C8000, 00020000) 64 MB P62: vm-linux (001E8000, 00010000) 32 MB P63: system (001F8000, 006B4800) 3433 MB P64: vendor (008AC800, 0020FB00) 1055 MB P65: userdata (00AC0000, 02F7DFDF) 23.75 GB Backuping modemst1 partition... File open failed C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP>_modemst1_0xa028_0xc00_07_01_2020_13_59_59.b in Suppot Team Healp p, li { white-space: pre-wrap; } | |
