07-09-2020, 18:35 | #1 (permalink) |
Insane Poster Join Date: Oct 2005 Location: hongkong Age: 38
Member: 192571 Status: Offline Thanks Meter: 5 | Xiaomi failed to replace the new ufs flash. [Answered] I create a new LUN, but I cannot change the AttrRefClkFreeq parameter, AttrRefClkFreeq=1 I need to change to AttrRefClkFreeq=0 Selected UFS BGA153 socket. Connected. Reading information. Manufacturer name: SKhynix Product name: H28S7Q302BMR Serial Number: 0780D02C8B270000 OEM ID: 01AD Page size : 4096 B Block size : 4096 B Block count : 15626240 Size : 59.61 GB (61040.00 MB) Reading attributes aborted. UFS has no active LUN. Connect successful. --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Write descriptor succes Write descriptor compare succes Disconnected. Selected UFS BGA153 socket. Connected. Reading information. Manufacturer name: SKhynix Product name: H28S7Q302BMR Serial Number: 0780D02C8B270000 OEM ID: 01AD Page size : 4096 B Block size : 4096 B Block count : 15626240 Size : 59.61 GB (61040.00 MB) AttrRefClkFreeq = 1 MaxDataInSize = 32768 MaxDataOutSize = 32768 Connect successful. --------------------------------------------------------------- Physical partition number: 0 Block count : 14426112 (0xDC2000) Size : 55.03 GB (56352.00 MB) Physical partition number: 1 Block count : 2048 (0x800) Size : 8.00 MB Physical partition number: 2 Block count : 2048 (0x800) Size : 8.00 MB Physical partition number: 3 Block count : 8192 (0x2000) Size : 32.00 MB Physical partition number: 4 Block count : 1179648 (0x120000) Size : 4.50 GB (4608.00 MB) Physical partition number: 5 Block count : 8192 (0x2000) Size : 32.00 MB RPMB: Authentication Key not yet programmed. |
07-10-2020, 07:55 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. In order to change Frequency, first You need to "Save Attributes" from the original UFS memory. You should perform such operation in "PWM Gear 1, after do "Write Attributes" at your new UFS memory Last edited by Medusa Box; 07-10-2020 at 08:08. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
07-10-2020, 10:07 | #3 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | if you don,t have your old UFS data it is not possible to change Chip for any Xiaomi new device |
