12-06-2011, 16:57 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: colombia
Member: 226132 Status: Offline Thanks Meter: 17 | Samsumg b7510 death [ Solved ] TAP0,IRLength:4,DeviceID:0x303C10E1 EmbeddedICE ver:6. Found bad block:0Found bad block:1Found bad block:2Found bad block:3Found bad block:4Found bad block:5Found bad block:6Found bad block:7Found bad block:8Found bad block:9Found bad block:10Found bad block:11Found bad block:12Found bad block:13Found bad block:14Found bad block:15Found bad block:16Found bad block:17Found bad block:18Found bad block:19Found bad block:20Found bad block:21Found bad block:22Found bad block:23Found bad block:24Found bad block:25Found bad block:26Found bad block:27Found bad block:28Found bad block:29Found bad block:30Found bad block:31Found bad block:32Found bad block:33Found bad block:34Found bad block:35Found bad block:36Found bad block:37Found bad block:38Found bad block:39Found bad block:40Found bad block:41Found bad block:42Found bad block:43Found bad block:44Found bad block:45Found bad block:46Found bad block:47Found bad block:48Found bad block:49Found bad block:50Found bad block:51Found bad block:52Found bad block:53Found bad block:54Found bad block:55Found bad block:56Found bad block:57Found bad block:58Found bad block:59Found bad block:60Found bad block:61Found bad block:62Found bad block:63Found bad block:64Found bad block:65Found bad block:66Found bad block:67Found bad block:68Found bad block:69Found bad block:70Found bad block:71Found bad block:72Found bad block:73Found bad block:74Found bad block:75Found bad block:76Found bad block:77Found bad block:78Found bad block:79Found bad block:80Found bad block:81Found bad block:82Found bad block:83Found bad block:84Found bad block:85Found bad block:86Found bad block:87Found bad block:88Found bad block:89Found bad block:90Found bad block:91Found bad block:92Found bad block:93Found bad block:94Found bad block:95Found bad block:96Found bad block:97Found bad block:98Found bad block:99Found bad block:100Found bad block:101Found bad block:102Found bad block:103Found bad block:104Found bad block:105Found bad block:106Found bad block:107Found bad block:108Found bad block:109Found bad block:110Found bad block:111Found bad block:112Found bad block:113Found bad block:114Found bad block:115Found bad block:116Found bad block:117Found bad block:118Found bad block:119Found bad block:120Found bad block:121Found bad block:122Found bad block:123Found bad block:124Found bad block:125Found bad block:126Found bad block:127Found bad block:128Found bad block:129Found bad block:130Found bad block:131Found bad block:132Found bad block:133Found bad block:134Found bad block:135Found bad block:136Found bad block:137Found bad block:138Found bad block:139Found bad block:140Found bad block:141Found bad block:142Found bad block:143Found bad block:144Found bad block:145Found bad block:146Found bad block:147Found bad block:148Found bad block:149Found bad block:150Found bad block:151Found bad block:152Found bad block:153Found bad block:154Found bad block:155Found bad block:156Found bad block:157Found bad block:158Found bad block:159Found bad block:160Found bad block:161Found bad block:162Found bad block:163Found bad block:164Found bad block:165Found bad block:166Found bad block:167Found bad block:168Found bad block:169Found bad block:170Found bad block:171Found bad block:172Found bad block:173Found bad block:174Found bad block:175Found bad block:176Found bad block:177Found bad block:178Found bad block:179Found bad block:180Found bad block:181Found bad block:182Found bad block:183Found bad block:184Found bad block:185Found bad block:186Found bad block:187Found bad block:188Found bad block:189Found bad block:190Found bad block:191Found bad block:192Found bad block:193Found bad block:194Found bad block:195Found bad block:196Found bad block:197Found bad block:198Found bad block:199Found bad block:200Found bad block:201Found bad block:202Found bad block:203Found bad block:204Found bad block:205Found bad block:206Found bad block:207Found bad block:208Found bad block:209Found bad block:210Found bad block:211Found bad block:212Found bad block:213Found bad block:214Found bad block:215Found bad block:216Found bad block:217Found bad block:218Found bad block:219Found bad block:220Found bad block:221Found bad block:222Found bad block:223Found bad block:224Found bad block:225Found bad block:226Found bad block:227Found bad block:228Found bad block:229Found bad block:230Found bad block:231Found bad block:232Found bad block:233Found bad block:234Found bad block:235Found bad block:236Found bad block:237Found bad block:238Found bad block:239Found bad block:240Found bad block:241Found bad block:242Found bad block:243Found bad block:244Found bad block:245Found bad block:246Found bad block:247Found bad block:248Found bad block:249Found bad block:250Found bad block:251Found bad block:252Found bad block:253Found bad block:254Found bad block:255Found bad block:256Found bad block:257Found bad block:258Found bad block:259Found bad block:260Found bad block:261Found bad block:262Found bad block:263Found bad block:264Found bad block:265Found bad block:266Found bad block:267Found bad block:268Found bad block:269Found bad block:270Found bad block:271Found bad block:272Found bad block:273Found bad block:274Found bad block:275Found bad block:276Found bad block:277Found bad block:278Found bad block:279Found bad block:280Found bad block:281Found bad block:282Found bad block:283Found bad block:284Found bad block:285Found bad block:286Found bad block:287Found bad block:288Found bad block:289Found bad block:290Found bad block:291Found bad block:292Found bad block:293Found bad block:294Found bad block:295Found bad block:296Found bad block:297Found bad block:298Found bad block:299Found bad block:300Found bad block:301Found bad block:302Found bad block:303Found bad block:304Found bad block:305Found bad block:306Found bad block:307Found bad block:308Found bad block:309Found bad block:310Found bad block:311Found bad block:312Found bad block:313Found bad block:314Found bad block:315Found bad block:316Found bad block:317Found bad block:318Found bad block:319Found bad block:320Found bad block:321Found bad block:322Found bad block:323Found bad block:324Found bad block:325Found bad block:326Found bad block:327Found bad block:328Found bad block:329Found bad block:330Found bad block:331Found bad block:332Found bad block:333Found bad block:334Found bad block:335Found bad block:336Found bad block:337Found bad block:338Found bad block:339Found bad block:340Found bad block:341Found bad block:342Found bad block:343Found bad block:344Found bad block:345Found bad block:346Found bad block:347Found bad block:348Found bad block:349Found bad block:350Found bad block:351Found bad block:352Found bad block:353Found bad block:354Found bad block:355Found bad block:356Found bad block:357Found bad block:358Found bad block:359Found bad block:360Found bad block:361Found bad block:362Found bad block:363Found bad block:364Found bad block:365Found bad block:366Found bad block:367Found bad block:368Found bad block:369Found bad block:370Found bad block:371Found bad block:372Found bad block:373Found bad block:374Found bad block:375Found bad block:376Found bad block:377Found bad block:378Found bad block:379Found bad block:380Found bad block:381Found bad block:382Found bad block:383Found bad block:384Found bad block:385Found bad block:386Found bad block:387Found bad block:388Found bad block:389Found bad block:390Found bad block:391Found bad block:392Found bad block:393Found bad block:394Found bad block:395Found bad block:396Found bad block:397Found bad block:398Found bad block:399Found bad block:400Found bad block:401Found bad block:402Found bad block:403Found bad block:404Found bad block:405Found bad block:406Found bad block:407Found bad block:408Found bad block:409Found bad block:410Found bad block:411Found bad block:412Found bad block:413Found bad block:414Found bad block:415Found bad block:416Found bad block:417Found bad block:418Found bad block:419Found bad block:420Found bad block:421Found bad block:422Found bad block:423Found bad block:424Found bad block:425Found bad block:426Found bad block:427Found bad block:428Found bad block:429Found bad block:430Found bad block:431Found bad block:432Found bad block:433Found bad block:434Found bad block:435Found bad block:436Found bad block:437Found bad block:438Found bad block:439Found bad block:440Found bad block:441Found bad block:442Found bad block:443Found bad block:444Found bad block:445Found bad block:446Found bad block:447Found bad block:448Found bad block:449Found bad block:450Found bad block:451Found bad block:452Found bad block:453Found bad block:454Found bad block:455Found bad block:456Found bad block:457Found bad block:458Found bad block:459Found bad block:460Found bad block:461Found bad block:462Found bad block:463 for more 3 hours. this is pictures |
12-08-2011, 10:52 | #7 (permalink) |
Product Supporter Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 33
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | One more success story ) You should post in the successfully repaired phones section . Best Regards Ort-Jtag TEAM |
01-07-2012, 20:52 | #8 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Colombia Age: 48
Member: 197360 Status: Offline Thanks Meter: 25 | sacan problem Dear team i click on scan and a fter a few seconds says this: TCK:RTCK Model:GT-B7510 arm.tap,pos:0,IRLength:4,DeviceID:0x203C00E1 Scan CPU failed(-4) |
01-10-2012, 17:35 | #10 (permalink) |
Member: 197360 Status: Offline Thanks Meter: 25 | process for repair? thanks, for your answer der team i was making some errors and i put this for other users 1. you must reset box with ORT_Plus_V1.00 2. use battery over 4.80 3. push power button now i have another quest there is repair file and raw file. whats the process for repair? |
10-04-2012, 05:04 | #11 (permalink) |
Freak Poster Join Date: Jan 2007 Location: colombia
Member: 423627 Status: Offline Thanks Meter: 261 | have same problem Vref:2.764V TCK:RTCK+ Model:AutoModel TAP0,IRLength:4,DeviceID:0x303C10E1 EmbeddedICE ver:6. CPUID:0x303C10E1,MSM7227,IOLevel:2.6V FlashID:0x00000000005000EC BlockSize:262144 PageSize:4096 Density:512MB TotalBlockNum:2048 Found bad block:0 Found bad block:1 Found bad block:2 Found bad block:3 |
10-05-2012, 07:18 | #12 (permalink) | |
Product Manager Join Date: Oct 2001 Location: GSMFABRICA Age: 43
Member: 6594 Status: Offline Sonork: 100.27285 Thanks Meter: 22,500 | Quote:
Best Regards Oz | |
plz solve this | avtarkaint | RIFFBOX | 2 | 12-09-2011 13:25 |
need china android iphone heard resate....Solved | samreen111 | Dragon Box | 6 | 12-08-2011 00:24 |
c1-01 reset counter - [SOLVED] | strangerboy | Advance-Box | 10 | 12-07-2011 16:34 |
i5510 imei repair dont work [SOLVED] | pabloo81 | SPT BOX | 4 | 12-07-2011 16:23 |
Problem reading info in Blackberry 9900 [SOLVED] | pititi1974 | PolarBox 3 | 1 | 12-07-2011 10:09 |
