12-02-2023, 05:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: colombo
Member: 399781 Status: Offline Thanks Meter: 94 | a207f frp now dead Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1414110FBFBA99FD, ,FW Ver.: 01.63 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:1784 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1414110FBFBA99FD, ,FW Ver.: 01.63 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:1784 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1414110FBFBA99FD, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:3031 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D4201000D96F086B6 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2019 Rev.0x1 eMMC NAME: GD6BMB , S/N: 890608 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 150363 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_ 890608_20231201_2009.extcsd Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0033800000 (3.750GB) Short EXT fs info: Size: 3.690GB Block size: 4.0KB Inode size: 256 Inodes: 241920 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x018B800000 (22.940GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1414110FBFBA99FD, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:3073 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D4201000D96F086B6 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2019 Rev.0x1 eMMC NAME: GD6BMB , S/N: 890608 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 150363 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found Formatting FRP... Detected LINUX(Android) CONFIG : 0x00185C2000 (32.0KB) formatting... Done. Detected LINUX(Android) PERSISTENT : 0x0031400000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x0175000000 (212.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x018B800000 (22.940GB) , formatting... Done. Done. Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1414110FBFBA99FD, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:3073 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D4201000D96F086B6 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2019 Rev.0x1 eMMC NAME: GD6BMB , S/N: 890608 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 150363 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_ 890608_20231201_2010.extcsd Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0033800000 (3.750GB) Short EXT fs info: Size: 3.690GB Block size: 4.0KB Inode size: 256 Inodes: 241920 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x018B800000 (22.940GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. |
12-02-2023, 11:38 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | try clk short........................... |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
