08-12-2020, 08:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | vivo y19 : Error: This emmc has write protection. Operation canceled Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100445636444D4202B6D790C2B6B1 EMMC CSD: D02701320F5903FFF6DBFFEF8E406069 EMMC Manufacture : SAMSUNG , EMMC NAME: DV6DMB , HEX: 445636444D42 , S/N: B6D790C2 , rev. 0x02 EMMC ROM 1 (Main User Data) Capacity: 119276 MB (001D1EC00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 97 , Response: Not Clean EMMC Permanent Write Protection: Yes Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x02 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: DV6DMB_B6D790C2_20200812_123740.extcsd EMMC Init completed. Error: This emmc has write protection. Operation canceled support team help how can flash this phone already used remove write protection button, writting always failed |
08-12-2020, 08:20 | #2 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | Checking security ... Running:SAMSUNG: Remove Write Protection... Z3X EasyJtag Software ver. 3.7.0.17 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:14000 kHz Removing write protection... Done. Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 914mV pin connected ok command: 994mV pin connected ok data0: 853mV pin connected ok data1: 848mV pin connected ok data2: 852mV pin connected ok data3: 854mV pin connected ok data4: 853mV pin connected ok data5: 850mV pin connected ok data6: 852mV pin connected ok data7: 852mV pin connected ok Box S/N: 7117BF7844FC6CC4, ,FW Ver.: 02.52 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100445636444D4202B6D790C2B6B1 eMMC CSD : D02701320F5903FFF6DBFFEF8E406069 eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2019 Rev.0x2 eMMC NAME: DV6DMB , S/N: 3067580610 eMMC NAME (HEX): 445636444D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 97 times EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DV6DMB_3067580610_20200812_1247.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found ------ Detected 44 partitions ------ P0 (RECOVERY) [0x8000 0x4000000] Size: 64.0MB P1 (MISC) [0x4008000 0x80000] Size: 512.0KB P2 (PARA) [0x4088000 0x80000] Size: 512.0KB P3 (EXPDB) [0x4108000 0x1400000] Size: 20.0MB P4 (FRP) [0x5508000 0x100000] Size: 1.0MB P5 (VBMETA) [0x5608000 0x800000] Size: 8.0MB P6 (BACKUP) [0x5e08000 0xa00000] Size: 10.0MB P7 (SURVIVAL) [0x6808000 0x4000000] Size: 64.0MB P8 (RESERVED) [0xa808000 0xa00000] Size: 10.0MB P9 (CUST) [0xb208000 0x4000000] Size: 64.0MB P10 (VGC) [0xf208000 0xc800000] Size: 200.0MB P11 (METADATA) [0x1ba08000 0x2000000] Size: 32.0MB P12 (NVCFG) [0x1da08000 0x2000000] Size: 32.0MB P13 (NVDATA) [0x1fa08000 0x4000000] Size: 64.0MB P14 (PERSIST) [0x23a08000 0x3000000] Size: 48.0MB P15 (PROTECT1) [0x26a08000 0x800000] Size: 8.0MB P16 (PROTECT2) [0x27208000 0xdf8000] Size: 13.968MB P17 (SECCFG) [0x28000000 0x800000] Size: 8.0MB P18 (SEC1) [0x28800000 0x200000] Size: 2.0MB P19 (PROINFO) [0x28a00000 0x300000] Size: 3.0MB P20 (EFUSE) [0x28d00000 0x80000] Size: 512.0KB P21 (BOOT_PARA) [0x28d80000 0x1a00000] Size: 26.0MB P22 (NVRAM) [0x2a780000 0x4000000] Size: 64.0MB P23 (LOGO) [0x2e780000 0x800000] Size: 8.0MB P24 (MD1IMG) [0x2ef80000 0x8000000] Size: 128.0MB P25 (SPMFW) [0x36f80000 0x100000] Size: 1.0MB P26 (SCP1) [0x37080000 0x600000] Size: 6.0MB P27 (SCP2) [0x37680000 0x600000] Size: 6.0MB P28 (SSPM_1) [0x37c80000 0x100000] Size: 1.0MB P29 (SSPM_2) [0x37d80000 0x100000] Size: 1.0MB P30 (GZ1) [0x37e80000 0x1000000] Size: 16.0MB P31 (GZ2) [0x38e80000 0x1000000] Size: 16.0MB P32 (LK) [0x39e80000 0x500000] Size: 5.0MB P33 (LK2) [0x3a380000 0x500000] Size: 5.0MB P34 (BOOT) [0x3a880000 0x4000000] Size: 64.0MB P35 (DTBO) [0x3e880000 0x800000] Size: 8.0MB P36 (TEE1) [0x3f080000 0x500000] Size: 5.0MB P37 (TEE2) [0x3f580000 0xa80000] Size: 10.500MB P38 (VENDOR) [0x40000000 0x60000000] Size: 1.500GB P39 (SYSTEM) [0xa0000000 0x140000000] Size: 5.0GB P40 (CACHE) [0x1e0000000 0x10000000] Size: 256.0MB P41 (USERDATA) [0x1f0000000 0x1b2b0f8000] Size: 108.671GB P42 (OTP) [0x1d1b0f8000 0x2b00000] Size: 43.0MB P43 (FLASHINFO) [0x1d1dbf8000 0x1000000] Size: 16.0MB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x00A0000000 (5.0GB) Short EXT fs info: Size: 4.920GB Block size: 4.0KB Inode size: 256 Inodes: 322560 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x01F0000000 (108.671GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. |
