Old 08-12-2020, 08:12   #1 (permalink)
rajeshbahri's Avatar
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
vivo y19 : Error: This emmc has write protection. Operation canceled
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 MHz
EMMC Device Information :
EMMC CID: 150100445636444D4202B6D790C2B6B1
EMMC CSD: D02701320F5903FFF6DBFFEF8E406069
EMMC Manufacture : SAMSUNG , EMMC NAME: DV6DMB , HEX: 445636444D42 , S/N: B6D790C2 , rev. 0x02
EMMC ROM 1 (Main User Data) Capacity: 119276 MB (001D1EC00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 97 , Response: Not Clean
EMMC Permanent Write Protection: Yes
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x02 / 0x01
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: DV6DMB_B6D790C2_20200812_123740.extcsd
EMMC Init completed.
support team help how can flash this phone
already used remove write protection button, writting always failed
Old 08-12-2020, 08:20   #2 (permalink)
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
Checking security ...
Running:SAMSUNG: Remove Write Protection...
Z3X EasyJtag Software ver. 3.7.0.17
Skip loading eMMC Addon Firmware
Box IO Level:1800 mV
CLK Rate:14000 kHz
Removing write protection...
Done.
Loading eMMC GEN2 Firmware... IO: 1800 mV
Initial pull results:
clock: 914mV pin connected ok
command: 994mV pin connected ok
data0: 853mV pin connected ok
data1: 848mV pin connected ok
data2: 852mV pin connected ok
data3: 854mV pin connected ok
data4: 853mV pin connected ok
data5: 850mV pin connected ok
data6: 852mV pin connected ok
data7: 852mV pin connected ok
Box S/N: 7117BF7844FC6CC4, ,FW Ver.: 02.52
CLK Rate:42000 kHz
Bus Width:8bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100445636444D4202B6D790C2B6B1
eMMC CSD : D02701320F5903FFF6DBFFEF8E406069
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2019 Rev.0x2
eMMC NAME: DV6DMB , S/N: 3067580610
eMMC NAME (HEX): 445636444D42
EMMC ROM1 (Main User Data) Capacity: 119276 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 97 times
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: DV6DMB_3067580610_20200812_1247.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB
Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214
Partition info successfully found
------ Detected 44 partitions ------
P0 (RECOVERY) [0x8000 0x4000000] Size: 64.0MB
P1 (MISC) [0x4008000 0x80000] Size: 512.0KB
P2 (PARA) [0x4088000 0x80000] Size: 512.0KB
P3 (EXPDB) [0x4108000 0x1400000] Size: 20.0MB
P4 (FRP) [0x5508000 0x100000] Size: 1.0MB
P5 (VBMETA) [0x5608000 0x800000] Size: 8.0MB
P6 (BACKUP) [0x5e08000 0xa00000] Size: 10.0MB
P7 (SURVIVAL) [0x6808000 0x4000000] Size: 64.0MB
P8 (RESERVED) [0xa808000 0xa00000] Size: 10.0MB
P9 (CUST) [0xb208000 0x4000000] Size: 64.0MB
P10 (VGC) [0xf208000 0xc800000] Size: 200.0MB
P11 (METADATA) [0x1ba08000 0x2000000] Size: 32.0MB
P12 (NVCFG) [0x1da08000 0x2000000] Size: 32.0MB
P13 (NVDATA) [0x1fa08000 0x4000000] Size: 64.0MB
P14 (PERSIST) [0x23a08000 0x3000000] Size: 48.0MB
P15 (PROTECT1) [0x26a08000 0x800000] Size: 8.0MB
P16 (PROTECT2) [0x27208000 0xdf8000] Size: 13.968MB
P17 (SECCFG) [0x28000000 0x800000] Size: 8.0MB
P18 (SEC1) [0x28800000 0x200000] Size: 2.0MB
P19 (PROINFO) [0x28a00000 0x300000] Size: 3.0MB
P20 (EFUSE) [0x28d00000 0x80000] Size: 512.0KB
P21 (BOOT_PARA) [0x28d80000 0x1a00000] Size: 26.0MB
P22 (NVRAM) [0x2a780000 0x4000000] Size: 64.0MB
P23 (LOGO) [0x2e780000 0x800000] Size: 8.0MB
P24 (MD1IMG) [0x2ef80000 0x8000000] Size: 128.0MB
P25 (SPMFW) [0x36f80000 0x100000] Size: 1.0MB
P26 (SCP1) [0x37080000 0x600000] Size: 6.0MB
P27 (SCP2) [0x37680000 0x600000] Size: 6.0MB
P28 (SSPM_1) [0x37c80000 0x100000] Size: 1.0MB
P29 (SSPM_2) [0x37d80000 0x100000] Size: 1.0MB
P30 (GZ1) [0x37e80000 0x1000000] Size: 16.0MB
P31 (GZ2) [0x38e80000 0x1000000] Size: 16.0MB
P32 (LK) [0x39e80000 0x500000] Size: 5.0MB
P33 (LK2) [0x3a380000 0x500000] Size: 5.0MB
P34 (BOOT) [0x3a880000 0x4000000] Size: 64.0MB
P35 (DTBO) [0x3e880000 0x800000] Size: 8.0MB
P36 (TEE1) [0x3f080000 0x500000] Size: 5.0MB
P37 (TEE2) [0x3f580000 0xa80000] Size: 10.500MB
P38 (VENDOR) [0x40000000 0x60000000] Size: 1.500GB
P39 (SYSTEM) [0xa0000000 0x140000000] Size: 5.0GB
P40 (CACHE) [0x1e0000000 0x10000000] Size: 256.0MB
P41 (USERDATA) [0x1f0000000 0x1b2b0f8000] Size: 108.671GB
P42 (OTP) [0x1d1b0f8000 0x2b00000] Size: 43.0MB
P43 (FLASHINFO) [0x1d1dbf8000 0x1000000] Size: 16.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x00A0000000 (5.0GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 322560
Short Android info:
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x01F0000000 (108.671GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done.
Old 08-12-2020, 12:25   #3 (permalink)
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
support team reply please , how can flash this emmc
Old 08-13-2020, 04:03   #4 (permalink)
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
Experts, please help me for this problem
Old 08-13-2020, 06:33   #5 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
eMMC 5.1 with WP (Write Protection) can't be "unlocked" from this state
you need change eMMC
Old 08-13-2020, 06:43   #6 (permalink)
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
hmmm
very difficult, to find 128gb emmc bga ic
anyway, thanks for reply
Page generated in 0.19846 seconds with 8 queries
