04-29-2022, 12:12 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1038150 Status: Offline Thanks Meter: 45 | a305f u6 I did emmc repair but it always sees the computer in exynos mode I'm using it for testing purposes as I just got the working phone easy box. eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_2576486770_20220429_1354.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x23800000] Size: 568.0MB P26 (PRODUCT) [0x160800000 0x19000000] Size: 400.0MB P27 (CACHE) [0x179800000 0x19000000] Size: 400.0MB P28 (OMR) [0x192800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x195a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x195f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x197300000 0xcf84fbe00] Size: 51.878GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Short EXT fs info: Size: 4.613GB Block size: 4.0KB Inode size: 256 Inodes: 302512 Short Android info: Build ID: PPR1.180610.011 Display Build ID: PPR1.180610.011.FA90_A305FDDU6ATI1 Release Incremental ID: FA90_A305FDDU6ATI1 Release Base ID: 9 Security Path: 2019-02-01 Device Model: SM-A305F Device Manufacturer: samsung Product ID: a30 Device Name A: a30dd Device Name B: a30 Architecture ABI: arm64-v8a Device manufacturer: samsung Build Description: a30dd-user 9 PPR1.180610.011 FA90_A305FDDU6ATI1 release-keys PDA ver.: FA90_A305FDDU6ATI1 Backup saved: BuildProp_20220429_1354.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (51.878GB) Short EXT fs info: Size: 9.0GB Block size: 4.0KB Inode size: 256 Inodes: 294912 Short userdata info: Unable to read gesture.key , code 2 Done. |
04-29-2022, 12:12 | #2 (permalink) |
Member: 1038150 Status: Offline Thanks Meter: 45 | CMD Pullup Level:476 mV CMD Active Level:1431 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_2576486770_20220428_1738.extcsd Partition info successfully found ------ Detected 34 partitions ------ P0 (DDI) [0x300000 0x100000] Size: 1.0MB P1 (ECT) [0x400000 0] Size: 0.0B P2 (BOTA0) [0x400000 0x400000] Size: 4.0MB P3 (BOTA1) [0x800000 0x800000] Size: 8.0MB P4 (EFS) [0x1000000 0x1400000] Size: 20.0MB P5 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P6 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P7 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P8 (CM) [0x4800000 0x800000] Size: 8.0MB P9 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P10 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P11 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P12 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P13 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P14 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P15 (MISC) [0x6d00000 0x200000] Size: 2.0MB P16 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P17 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P18 (DTB) [0xc800000 0x800000] Size: 8.0MB P19 (DTBO) [0xd000000 0x800000] Size: 8.0MB P20 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P21 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P22 (STEADY) [0x10580000 0x400000] Size: 4.0MB P23 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P24 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P25 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P26 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P27 (VENDOR) [0x13d000000 0x23800000] Size: 568.0MB P28 (PRODUCT) [0x160800000 0x19000000] Size: 400.0MB P29 (CACHE) [0x179800000 0x19000000] Size: 400.0MB P30 (OMR) [0x192800000 0x3200000] Size: 50.0MB P31 (CP_DEBUG) [0x195a00000 0x500000] Size: 5.0MB P32 (NAD_FW) [0x195f00000 0x1400000] Size: 20.0MB P33 (USERDATA) [0x197300000 0] Size: 0.0B ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Blocks Reading Error (0x11000400 , 2 , Reason: CMD CRC Error ) Unable to mount SYSTEM , code : 5 --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (0.0B) Unable to mount USERDATA , code : 22 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2600 mV Box S/N: 14D62252362836C4, ,FW Ver.: 02.53 CMD Pullup Level:474 mV CMD Active Level:1430 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_2576486770_20220428_1738.extcsd Partition info successfully found ------ Detected 34 partitions ------ P0 (DDI) [0x300000 0x100000] Size: 1.0MB P1 (ECT) [0x400000 0] Size: 0.0B P2 (BOTA0) [0x400000 0x400000] Size: 4.0MB P3 (BOTA1) [0x800000 0x800000] Size: 8.0MB P4 (EFS) [0x1000000 0x1400000] Size: 20.0MB P5 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P6 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P7 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P8 (CM) [0x4800000 0x800000] Size: 8.0MB P9 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P10 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P11 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P12 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P13 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P14 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P15 (MISC) [0x6d00000 0x200000] Size: 2.0MB P16 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P17 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P18 (DTB) [0xc800000 0x800000] Size: 8.0MB P19 (DTBO) [0xd000000 0x800000] Size: 8.0MB P20 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P21 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P22 (STEADY) [0x10580000 0x400000] Size: 4.0MB P23 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P24 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P25 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P26 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P27 (VENDOR) [0x13d000000 0x23800000] Size: 568.0MB P28 (PRODUCT) [0x160800000 0x19000000] Size: 400.0MB P29 (CACHE) [0x179800000 0x19000000] Size: 400.0MB P30 (OMR) [0x192800000 0x3200000] Size: 50.0MB P31 (CP_DEBUG) [0x195a00000 0x500000] Size: 5.0MB P32 (NAD_FW) [0x195f00000 0x1400000] Size: 20.0MB P33 (USERDATA) [0x197300000 0] Size: 0.0B ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Blocks Reading Error (0x11000400 , 2 , Reason: CMD CRC Error ) Unable to mount SYSTEM , code : 5 --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (0.0B) Unable to mount USERDATA , code : 22 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2600 mV Box S/N: 14D62252362836C4, ,FW Ver.: 02.53 CMD Pullup Level:472 mV CMD Active Level:1428 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x0179800000 (400.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x0197300000 (0.0B) , formatting... Done. Done. Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2600 mV Box S/N: 14D62252362836C4, ,FW Ver.: 02.53 CMD Pullup Level:472 mV CMD Active Level:1428 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table CMD Pullup Level:472 mV CMD Active Level:1428 mV Length limit is enabled! Input file : E:\ufi\Samsung\SM-A305F(RP1A.200720.012.A305FDDU6CUI3-11-RP1A.200720.012)[KLMCG2UCTA-B041_83D55B25]\user_part\efs.img Writing 0001400000 bytes to 0001000000... ROM1 (USER ROM) Done, time taken: 17 sec. Average Write Speed: 1222 kB/s Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2600 mV Box S/N: 14D62252362836C4, ,FW Ver.: 02.53 CMD Pullup Level:472 mV CMD Active Level:1428 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_2576486770_20220428_1740.extcsd Partition info successfully found ------ Detected 34 partitions ------ P0 (DDI) [0x300000 0x100000] Size: 1.0MB P1 (ECT) [0x400000 0] Size: 0.0B P2 (BOTA0) [0x400000 0x400000] Size: 4.0MB P3 (BOTA1) [0x800000 0x800000] Size: 8.0MB P4 (EFS) [0x1000000 0x1400000] Size: 20.0MB P5 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P6 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P7 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P8 (CM) [0x4800000 0x800000] Size: 8.0MB P9 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P10 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P11 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P12 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P13 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P14 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P15 (MISC) [0x6d00000 0x200000] Size: 2.0MB P16 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P17 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P18 (DTB) [0xc800000 0x800000] Size: 8.0MB P19 (DTBO) [0xd000000 0x800000] Size: 8.0MB P20 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P21 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P22 (STEADY) [0x10580000 0x400000] Size: 4.0MB P23 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P24 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P25 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P26 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P27 (VENDOR) [0x13d000000 0x23800000] Size: 568.0MB P28 (PRODUCT) [0x160800000 0x19000000] Size: 400.0MB P29 (CACHE) [0x179800000 0x19000000] Size: 400.0MB P30 (OMR) [0x192800000 0x3200000] Size: 50.0MB P31 (CP_DEBUG) [0x195a00000 0x500000] Size: 5.0MB P32 (NAD_FW) [0x195f00000 0x1400000] Size: 20.0MB P33 (USERDATA) [0x197300000 0] Size: 0.0B ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Blocks Reading Error (0x11000400 , 2 , Reason: CMD CRC Error ) Unable to mount SYSTEM , code : 5 --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (0.0B) Unable to mount USERDATA , code : 22 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. |
04-29-2022, 12:13 | #3 (permalink) |
Member: 1038150 Status: Offline Thanks Meter: 45 | CMD Pullup Level:476 mV CMD Active Level:1431 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343202999211727603 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2019 Rev.0x2 eMMC NAME: CUTA42 , S/N: 2576486770 eMMC NAME (HEX): 435554413432 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMCG2UCTA-B041/64GB @FBGA169 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_2576486770_20220428_1738.extcsd Partition info successfully found ------ Detected 34 partitions ------ P0 (DDI) [0x300000 0x100000] Size: 1.0MB P1 (ECT) [0x400000 0] Size: 0.0B P2 (BOTA0) [0x400000 0x400000] Size: 4.0MB P3 (BOTA1) [0x800000 0x800000] Size: 8.0MB P4 (EFS) [0x1000000 0x1400000] Size: 20.0MB P5 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P6 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P7 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P8 (CM) [0x4800000 0x800000] Size: 8.0MB P9 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P10 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P11 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P12 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P13 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P14 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P15 (MISC) [0x6d00000 0x200000] Size: 2.0MB P16 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P17 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P18 (DTB) [0xc800000 0x800000] Size: 8.0MB P19 (DTBO) [0xd000000 0x800000] Size: 8.0MB P20 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P21 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P22 (STEADY) [0x10580000 0x400000] Size: 4.0MB P23 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P24 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P25 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P26 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P27 (VENDOR) [0x13d000000 0x23800000] Size: 568.0MB P28 (PRODUCT) [0x160800000 0x19000000] Size: 400.0MB P29 (CACHE) [0x179800000 0x19000000] Size: 400.0MB P30 (OMR) [0x192800000 0x3200000] Size: 50.0MB P31 (CP_DEBUG) [0x195a00000 0x500000] Size: 5.0MB P32 (NAD_FW) [0x195f00000 0x1400000] Size: 20.0MB P33 (USERDATA) [0x197300000 0] Size: 0.0B ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Blocks Reading Error (0x11000400 , 2 , Reason: CMD CRC Error ) Unable to mount SYSTEM , code : 5 --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (0.0B) Unable to mount USERDATA , code : 22 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. |
