10-23-2019, 08:03 | #16 (permalink) |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100303030303030562016061354D1 EMMC CSD: 902701320F5903FFF6DB7FE08A40403B EMMC Manufacture : SAMSUNG , EMMC NAME: 000000 , HEX: 303030303030 , S/N: 20160613 , rev. 0x56 EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (000000080000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x00 / 0x00 / 0x00 Supported partition features [PARTITIONING_SUPPORT]: 0x03 EMMC Init completed. Warning: Maybe your emmc damaged eMMC are unusable. |
10-23-2019, 11:53 | #17 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,949 | Quote:
if z3x EasyJTAG have firmware to this eMMC - you can try restore it (Update Firmware button) | |
09-09-2020, 15:01 | #26 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 356023 Status: Offline Thanks Meter: 3 | Emmc name: 000000 ayuda por favor 2/9/2020 19:44:02> EasyJTAG API ver. 3401 2/9/2020 19:44:02> Setting IO Levels to 1.8V 2/9/2020 19:44:02> Setting frequence to 36 MHz 2/9/2020 19:44:02> EasyJTAG Box Serial = 0DFDFF5077196AEB 2/9/2020 19:44:02> EasyJTAG Box Firmware = 2.5301 2/9/2020 19:44:03> Setting interface to EasyJtag2/ISP 2/9/2020 19:44:03> Setting bus width to 1 Bit 2/9/2020 19:44:03> Setting frequence to 36 MHz 2/9/2020 19:44:03> CMD Pullup Level: 1788 mV 2/9/2020 19:44:03> CMD Active Level: 1849 mV 2/9/2020 19:44:03> eMMC Init returned = 0 2/9/2020 19:44:04> EMMC Device Information : 2/9/2020 19:44:04> EMMC CID: 150100303030303030562014031443C7 2/9/2020 19:44:04> EMMC CSD: 902701320F5903FFF6DB7FE08A40403B 2/9/2020 19:44:04> EMMC Manufacture : SAMSUNG , EMMC NAME: 000000 , HEX: 303030303030 , S/N: 20140314 , rev. 0x56 2/9/2020 19:44:04> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2016 2/9/2020 19:44:04> EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000) 2/9/2020 19:44:04> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (000000080000) 2/9/2020 19:44:07> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean 2/9/2020 19:44:07> EMMC Permanent Write Protection: No 2/9/2020 19:44:07> EMMC Temporary Write Protection: No 2/9/2020 19:44:07> Extended CSD Information : 2/9/2020 19:44:07> Extended CSD rev: 1.5 (MMC 4.41) 2/9/2020 19:44:07> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 2/9/2020 19:44:07> Boot Bus Config: 0x00 , width 1bit 2/9/2020 19:44:07> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 2/9/2020 19:44:07> Supported partition features [PARTITIONING_SUPPORT]: 0x03 2/9/2020 19:44:07> Device supports partitioning features 2/9/2020 19:44:07> Device can have enhanced technological features in partitions and user data area 2/9/2020 19:44:07> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 2/9/2020 19:44:07> EMMC Init completed. 2/9/2020 19:44:07> 2/9/2020 19:44:07> Warning: Maybe your emmc damaged 2/9/2020 19:44:07> 2/9/2020 19:44:07> eMMC are unusable. 2/9/2020 19:44:07> |
09-09-2020, 19:47 | #27 (permalink) | |
if it an old eMMC - you can try to repair firmware Ypu can see all available firmwares at Z3x EasyJTAG/Firmwares folder | |
12-15-2022, 11:47 | #30 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | How To Fix│Unusable eMMC│Dead eMMC│Repair Possible by eMMC Firmware Update ✔ Easy Jt How To Fix│Unusable eMMC│Dead eMMC│Repair Possible by eMMC Firmware Update ✔ Easy Jtag Plus You can only repair Possible Some of the dead eMMC not At All. If You do have tested the eMMC firmware for the same build name as your eMMC. |
