10-24-2020, 14:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | any work around to flash faster than 1mhz? i have here xcover 4s with mdm lock no download mode so i try to write combination directly by isp connected the pinouts and the emmc is detected and can be read even in 36mhz @ 1bit my problem is i connot write it with even at 6mhz the only thing that work is on 1mhz and even it has some errors sometimes.. it consumes about 5 to 6 hours to complete a combination flashing.. i have 20pcs of this phone and the owner can only wait for 3days..i think i can managed it without even sleping but i think its too much |
10-24-2020, 16:44 | #2 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | managed to make it faster..just flashed sboot.bin param.bin cm.bin vbmeta.img boot.img recovery.img dt.img dtbo.img and 2% of system.img now i have download mode with errors so just continued to flashed it by z3x box.. |
10-25-2020, 11:19 | #5 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | ============ Important requirements that must be met for a quality ISP connection: - GND wire should be much thicker compared to others - the length of all wires must be same - the length of all wires should be kept to a minimum. Best length is 5-10 centimeters CLK clock at ISP mode determines the data trarsfer speed beetwin eMMC and box. If the above requirements are met, the stability of operation is ensured at frequencies up to 24-36MHz. The best performance is from 14-24MHz. There is no need to use lower frequencies. ============ you wires is long you gnd wire not ok Last edited by layder; 10-25-2020 at 11:34. |
The Following 7 Users Say Thank You to layder For This Useful Post: |
10-26-2020, 09:40 | #6 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | i make like this..tried on a faster computer with ssd but nothings changed..im still able to read at 36mhz but writing only works @1mhz thank you for the reply il just make it in another way |
10-26-2020, 11:02 | #7 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
alsio you need change VIO for best results for device with prolems I never use 1Mhz 12Mhz and faster always work - GND wire should be much thicker compared to others Last edited by layder; 10-26-2020 at 11:16. | |
The Following User Says Thank You to layder For This Useful Post: |
10-26-2020, 14:33 | #8 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | https://ibb.co/nkBg089 my image was not uplaoded from my message above..i was talking about this i was not having problem with my wires before in other models can write using it @24mhz maybe i will be needing pullup resistors for this model |
