07-01-2020, 13:21 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Help s6570m how to repair boot? Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63 CMD Pullup Level:1928 mV CMD Active Level:2052 mV Box IO Level:1850 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004A4A533030410386B1493F80D0 eMMC CSD : D02701320F5903FFF6DBFFE78A404056 eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2013 Rev.0x3 eMMC NAME: JJS00A , S/N: 2259765567 eMMC NAME (HEX): 4A4A53303041 IC Name: Samsung , KMJJS000WA-B409/4GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: JJS00A_2259765567_20200701_1514.extcsd Found invalid GPT and valid MBR; converting MBR to GPT format Detected 23 meta partitions : Meta partition 0 Meta partition A155 Meta partition A156 Meta partition A157 Meta partition A158 Meta partition A159 Meta partition A15A Meta partition A15B Meta partition A15C Meta partition A15D Meta partition A15E Meta partition A15F Meta partition A160 Meta partition A161 Meta partition A162 Meta partition A163 Meta partition A164 Meta partition A165 Meta partition A166 Meta partition A167 Meta partition A168 Meta partition A169 Meta partition A16A You will need to delete this partition or resize it in another utility. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB Disk identifier (GUID): 8E424302-D59A-2A0B-9927-ADCB24387D0E Logical sector size: 0x200 bytes ,First/Last usable sector: 34,7634910 Partition info successfully found Done. |
