08-12-2020, 20:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | box firmware update problem when press ok it shows like below.. continusly..30 minute..and continue same thing easy jtag sw working.. only problem for easy jtag plus Sabah Mangattupulam |
08-12-2020, 20:57 | #2 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | if you are using window 10 disable driver signature search in google than update driver you will see easyjtag programing port in device manager then plus exe will work or use emmcmanager tool |
The Following User Says Thank You to chand_gee For This Useful Post: |
08-13-2020, 07:58 | #3 (permalink) | |
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | Quote:
thank you for ur reply..but my problem still same after disabling driver signature,, same problem.. only detect box updating port..., when using jtag classic it is working again but when open jtag plus the same problem again emmc manager tool not see option to update again expect ur help | |
08-13-2020, 12:59 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | After box detect at update port, software is flash it and box will be detect on normal state |
The Following User Says Thank You to layder For This Useful Post: |
08-13-2020, 14:05 | #5 (permalink) | |
after 30 minutes it contioues.. seraching card..updating box..all done then restart software.. serachign card ..updating box..all done ... ............. ........... | |
08-16-2020, 07:46 | #7 (permalink) |
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | Problem solved... thx all jtag classic sw was old ..one, used new version of jtag classic and updated box firmware using that... then plus also working Sabah Mangattupulam |
