12-29-2015, 13:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Write Block Failed, Reason: Write Block Verify Error In I9300 Code: [ 29/12/2015 10:55:00 AM ] [Update] You have latest firmware DB [ 29/12/2015 10:55:00 AM ] Operation: Flash [ 29/12/2015 10:55:00 AM ] Selected model: GT-I9300 [ 29/12/2015 10:55:00 AM ] Software version: 20.5 [ 29/12/2015 10:55:00 AM ] [ 29/12/2015 10:55:00 AM ] File analysis... OK [ 29/12/2015 10:55:00 AM ] Total file size: 0x59D4F3F4 (1437 Mb) [ 29/12/2015 10:55:00 AM ] Searching USB Flash Interface... detected COM24 [ 29/12/2015 10:55:00 AM ] Setup connection... OK [ 29/12/2015 10:55:00 AM ] Reading PIT from phone... error http://forum.gsmhosting.com/vbb/f672...-jtag-1799790/ but Again-5 this error coming Code: Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0B0170135E37F259, ,FW Ver.: 01.52 CMD Pullup Level:763 mV CMD Active Level:2237 mV eMMC Device Information EMMC CID : 15010056545530304DF103AE180B5FF0 EMMC CSD : D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 Rev.0xF1 EMMC NAME: VTU00M , S/N: 61741067 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU00M_ 61741067_20151229_1724.extcsd Done. Checking NAND Image : C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder (3)\EMMC_ROM2_00000000_00200000.bin File successefuly loaded! Processing file...C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder (3)\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:763 mV CMD Active Level:2237 mV Input file : C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder (3)\EMMC_ROM2_00000000_00200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Block Failed, Reason: Write Block Verify Error Done. Processing file...C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder (3)\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:763 mV CMD Active Level:2237 mV Input file : C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder (3)\EMMC_ROM2_00000000_00200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Block Failed, Reason: Write Block Verify Error Done. Thanks & Regards: Gopal Parmar |
12-29-2015, 14:39 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
12-29-2015, 15:09 | #3 (permalink) | |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
I Was Try But Sir Again-2 This ERROR Is Coming During eMMC Firmware 1.First I Load PIT file ( GT-I9300_mx_20120329.pit) 2.Second i load firmware ( I9300XWUGML4_I9300ODDGML4_I9300DDUGMK1_HOME.tar.md 5 ) 3.After WRITE eMMC 4.But Again-2 tHIS error Coming: Please Sir Help Me Thanks & Regards: Gopal Parmar | |
12-30-2015, 09:37 | #6 (permalink) | |
Remove Write Protection Successfully But Now New Problem Coming During Write Full Dump Error Name:DATA SND CRC Error Code: Checking NAND Image : C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder\EMMC_ROM1_00000000_20000000.bin File successefuly loaded! Processing file...C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mV CMD Active Level:2237 mV Input file : C:\Documents and Settings\admin\Desktop\New Folder (4)\New Folder\EMMC_ROM1_00000000_20000000.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Retry writing adress 0x00000000 (Attempt #1)... Retry Fail! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail! Write Block Failed, Reason: DATA SND CRC Error Done. | |
12-31-2015, 12:15 | #9 (permalink) | |
Because When I Update Firmware Error Is Coming http://forum.gsmhosting.com/vbb/11509636-post3.html | |
12-31-2015, 14:23 | #10 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Dont upgrade firmware bro, just factory reset and format nand - write ext cid - write rom 1 - write room 2 - write 512 mb user area i suggest, using file from easyjtag support only. if all fine, then your phone will enter download mode when you press volume down menu and power on |
12-31-2015, 20:24 | #11 (permalink) | |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | Quote:
flash 4.3 factory firmware with pit and boot file on emmc odin while soldring emmc.... | |
