08-09-2018, 17:29 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2155333 Status: Offline Thanks Meter: 2 | Can help e5553 write dump seeting EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2015 Rev.0x1 EMMC NAME: R311MB , S/N: 2590695590 EMMC NAME (HEX): 523331314D4200 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.128 (MMC Unknown) Boot configuration [PARTITION_CONFIG: 0x80] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x80. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x00 Device NOT support partitioning feature Device cannot have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: R311MB_2590695590_20180809_2127.extcsd Done. |
08-09-2018, 17:57 | #2 (permalink) |
Member: 2155333 Status: Offline Thanks Meter: 2 | Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1835 mV CMD Active Level:1928 mV Input file : C:\Users\SA COMMUNICATIN\Desktop\SONY_C5_E5553_emmc_direct_dum p_520MB\SONY_C5_E5553_emmc_direct_dump_520MB\EMMC_ ROM1_R311MB_805756471_00000000_20000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Error writing address 0x00000000 Error Code:-7 Reason ATA SND Timeout Error Retry writing address 0x0000000000 (Attempt #0)... Retry failed at address 0x00000000 Error Code:-8 Reason ATA SND CRC Error Retry writing address 0x0000000000 (Attempt #0)... Retry failed at address 0x00000000 Error Code:-7 Reason ATA SND Timeout Error Retry writing address 0x0000000000 (Attempt #0)... Retry failed at address 0x00000000 Error Code:-4 Reason ATA RCV CRC Error Retry writing address 0x0000000000 (Attempt #0)... Retry failed at address 0x00000000 Error Code:-4 Reason ATA RCV CRC Error Retry writing address 0x0000000000 (Attempt #0)... Retry failed at address 0x00000000 Error Code:-7 Reason ATA SND Timeout Error Write Block Failed, Reason: DATA SND Timeout Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1835 mV CMD Active Level:1938 mV Can't init device, Reason: DATA RCV CRC Error Done. Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1835 mV CMD Active Level:1938 mV Can't init device, Reason: DATA RCV CRC Error Done. |
08-09-2018, 17:57 | #3 (permalink) |
08-09-2018, 22:27 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,949 | Quote:
Replace you eMMC | |
