Can't init device, Reason: CMD Timeout Error HELP PLZ |
try to read help for SW you posted info not enouth for any answer |
Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63 CMD Pullup Level:360 mV CMD Active Level:1980 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. i have the same problem. all phones i connect with easyjtag box i get same error i also change adapter but still same error i used other tool it connect fine.could it be box problem? if yes how to fix? |
z3x old box is produced at 2014 -2017 this box was disigned for JTAG, not eMMC eMMC function is been added later and need external third-party power adapter I can't know that adapter you use and that type of connection you use anybody can't help you without detail describe you situation |
same adapters i used before and used to work perfectly fine for emmc i even bought new emmc adapter but same error.maybe box is the problem or new software updates not compatible with old box |
software work with box firmware and box firmware for old box 1.63 is not changed from 2017 (+_) |
